X type radio antenna plug
Old Feb 16, 2010 | 01:59 PM
nein14's Avatar
Smile X type radio antenna plug
does anyone know if I can reach the antenna plug on a 04' X type radio from removal of the ash tray and reaching up to the radio unit?
from pictures I've seen it appears that the optic antenna cable is in one of the bottom corners of the CD player , picture would be great!
Old Feb 17, 2010 | 06:43 AM
The Chris X's Avatar
Instead of the ashtray try removing one or both of the kick panels on the side of the center console. There is one screw near the seat. Take that screw out then gently pry down and out and the panel will pop out of the clip retainers. You can see most of the wiring behind the radio from there.
Old Jun 24, 2012 | 06:18 AM
skull1959's Avatar
want to change my aerial on 2005 x type what adapter do I need
Old Mar 7, 2024 | 09:38 PM
Keith Newman's Avatar
Default Lift out the hazard, warning, patch undo in the ashtray, undo screws, stereo and just
It’s just as easy to take the unit out. Just lift up the ashtray, undo the screws. Go to your hazard, warning and click it and do the screws and stereo and just pull out that way you’ll have no problems.
Barry_Tucker
May 3, 2019 08:16 PM
Gator8
Sep 23, 2011 11:50 PM
chelltom
Mar 27, 2009 07:44 PM
teekster
Mar 7, 2009 07:59 PM
GreenJewel
Dec 19, 2008 02:27 PM
