x type REAR indicators not working
Old Sep 12, 2018 | 06:54 AM
Graham W's Avatar
Originally Posted by Thermo
iownme, I go back to how the switches feed into the circuit. The switches (both turn and hazard) are inputs to the GEM module. It is a yes or no signal (ie, you have a ground or you don't). The GEM module takes this yes/no signal and if it is a yes (ie, the switch grounds the wire), then it makes the lights flash. No ground, no flash. It isn't a turn signal because if you look at the turn signal outputs (ie, IP53-1 and IP53-3 from Fig 8.2 and 8.3), those 2 wires power both the front and rear turn signals. Since the front turn signals work, we know those lines through IP53-1/3 are good. Since all the turn signals work with the hazard switch, we know that is good. So, all that you are left with is the GEM module or some funny problem that I am not seeing. I have a hard time believing that the new GEM Module became bad just by installing it (the GEM module was proven working properly prior to being removed from the donor car).
This is where I am scratching my head, trying to understand what is going on. I feel like I am missing something and wish I could put my hands on the car to figure this out.
I thought that was the case with the hazzard switch.
When I changed the GEM module did I need to change anything else on the car to update any software.
Is it worth disconnecting the battery for a few hours to see if that does a reset of the systems, or could that cause more issues?
Old Sep 12, 2018 | 06:57 AM
Graham W's Avatar
Originally Posted by iownme
i want my hands on it too!
graham....where are you located?
Haha that could be an issue. I am in Plymouth, England
Old Sep 12, 2018 | 09:33 AM
iownme's Avatar
i just have a feeling for hazard switch or its related relays/fuses/connections.
i would absoluttely try a battery disconnect
Old Sep 12, 2018 | 11:19 AM
iownme's Avatar
so...after consulting the wiring diagrams i have to agree with thermo about it being the gem. My ilogical side is still fighting that though.
so at least another gem is still a good posibilty at this point ;@)
my folks live just down the road from you in Wiliton....ma makes a great cuppa but her jaguar wiring skills are a bit lacking
Old Sep 12, 2018 | 03:38 PM
Thermo's Avatar
Veteran: Navy
Graham, I would say to disconnect the battery and let the car set for like 5 minutes (really only need about 30 seconds, but just to be sure). Then see what you have then. I can't imagine another module affecting things, but gotta love modern day computers. The system is not that difficult. But, what you are describing is not passing the "how it should operate" check.
Old Sep 13, 2018 | 04:10 AM
Graham W's Avatar
Latest update -
Disconnected the battery for 1 hour while I popped out. Came back, reconnected battery and made no difference, rear indicators still not working from stalk but fine from hazard switch.
Disconnected battery again, fitted 3rd GEM unit, refitted battery and still the same issue.
For my own sanity as much as anything else I disconnected the hazard switch but that made no difference to indicators. Still working on front and side but not rear. Re-connected hazard and checked both connectors full engaged, again no difference
I really am confused now
Old Sep 13, 2018 | 05:50 AM
Graham W's Avatar
There are 5 coloured connectors on the GEM module, which one is the indicator one and does anyone have a diagram to show which cable goes where so I can check for power where is should be.
Old Sep 13, 2018 | 07:57 AM
  #28
iownme's Avatar
do you have the trailer/towing package?
from what i can see, the output from the gem for the rear turn lights are
orange/yellow for left turn
brown/red for right turn
Old Sep 13, 2018 | 08:04 AM
Graham W's Avatar
Yes I do. I've plugged a light board into the 7 pin socket and the indicators on the light board act exactly the same as the rear indicators. Work fine on Hazards and not at all from indicator stalk
Old Sep 13, 2018 | 08:11 AM
  #30
iownme's Avatar
i just edited my last post to include wire colors...ignore that as the trailer package is different...
i'll update soon
Old Sep 13, 2018 | 08:14 AM
  #31
iownme's Avatar
do both rear fog lights work and reverse lights?
Old Sep 13, 2018 | 08:17 AM
  #32
iownme's Avatar
there is a trailer towing module.
the turn signal power comes from that,not the gem, so either a disconnected connector or a bad TT module.
im still checking diagrams.....
Old Sep 13, 2018 | 08:23 AM
  #33
Graham W's Avatar
do both fog lights work and reverse lights?
This is getting even more confusing. The light board I have does not have a reversing light but when plugged into another car (just checked again) then all lights work correctly (driving, brakes, hazards and indicators. When I plug the light board into the Jag ONLY the hazards work. Driving lights, brake lights and indicators all DO NOT work.
Old Sep 13, 2018 | 08:25 AM
  #34
Graham W's Avatar
Ah, this is starting to look more promising. Where is this module and what am I looking for?
Old Sep 13, 2018 | 08:44 AM
  #35
Graham W's Avatar
Found a box in the spare wheel well that looks like its been at the bottom of the sea for a few years. Looks like this is the problem. Just got to figure out now how to clean it and repair the broken connections
Tried to attach some pics but don't seem to be able to
Old Sep 13, 2018 | 08:48 AM
  #36
iownme's Avatar
yes, were heading in the right direction.
just dont turn yet....haha
with this new info im sure thermo will be able to finish this if i cant.
i dont know the TT module location but what you just said about the reverse light etc all adds up according to the wiring diagram.
those diags are not my strong point but thermo is good with them.
there appears to be 4 connectors between the gem and bulbs, including in and out of the TT module.
that line includes rear turn lights and reverse and i think fog
Old Sep 13, 2018 | 08:51 AM
  #37
Graham W's Avatar
I'm pretty sure this is it. All the connectors age green and there are 2 snapped cables. I have some pics hopefully here
Old Sep 13, 2018 | 08:55 AM
  #38
iownme's Avatar
that looks like the problem
Old Sep 13, 2018 | 09:10 AM
  #39
iownme's Avatar
in the spare wheel well! !
its always in the last place you think to look...haha
glad we could figure it out!
it s been bugging me since yesterday, i'm sure thermo will sleep better now too ;@)
Old Sep 13, 2018 | 09:12 AM
  #40
Graham W's Avatar
Thanks for all your help. I just need to try and find one of these units now, it is not proving easy.
