X-Type starter motor
Old Sep 16, 2015 | 12:28 PM
Roger Geirnaert's Avatar
Default X-Type starter motor
Can someone tell if the starter is the same for an Auto and a Manual 2006 2.5ltr petrol?
Old Sep 16, 2015 | 01:12 PM
dwclapp's Avatar
Automatics and Manuals use the same starter motor. Here's the part #'s:
Old Sep 16, 2015 | 01:31 PM
Cheers buddy, thanks for the that.
Old Sep 17, 2015 | 07:19 AM
geoffbp58's Avatar
Is your car a manual by any chance and sounds like it's grinding? If so, there's an excellent possibility that clutch goo is binding the drive gear. I was ready to replace my starter; found info in these forums and removed my starter and cleaned it; been working like new ever since! It's even a relatively simple job. Cheers!
Old Sep 17, 2015 | 07:33 AM
Mine is an auto but thanks anyway for replying. Cheers
Old Sep 17, 2015 | 07:23 PM
Dr dome's Avatar
I have a few starters if you need one. pm me and we can go from there.
Good luck,
The Dr!
Old Sep 20, 2015 | 07:47 PM
deman1134's Avatar
Thank you for that! Only had mine a few months now but a couple times a couple weeks ago it did the grinding and not catching stuff, I thought maybe damaged teeth or something, but hopefully it's just this, mines a 5spd. What is this clutch goo?
Old Sep 21, 2015 | 06:51 AM
geoffbp58's Avatar
That's my super- technical name for the dust and residue that comes off your clutch as it wears, and it all seems to accumulate on the shaft for the drive gear. It will make perfect sense when you get the starter out. I could barely pry the gear up and down on mine; just used a bit of brake cleaner and judicious use of compressed air, good as new. I gather it's pretty common. Good luck!
Old Oct 11, 2015 | 03:43 PM
donaldbarto's Avatar
Good luck,
The Dr!
Hi:
I see that You are parting 2004'
do you have the battery box if so what would
be the cost to Plains, Pa.
Old Oct 12, 2015 | 01:01 PM
Dr dome's Avatar
Hey Don.
I have one complete. My cell is 484-903-4813. Let me know.
Thanks,
The Dr!
Jaguar Forums Editor
Jaguar Press release
Sep 17, 2015 11:18 AM
Sep 17, 2015 01:08 AM
Busa R
Sep 10, 2015 07:28 PM
1964Daimler
Sep 9, 2015 11:28 AM
Doovoe
XJ40 ( XJ81 )
Sep 6, 2015 10:54 AM
