x type sticking rear left caliper e brake
Old Aug 8, 2015 | 06:43 PM
TreVoRTasmin's Avatar
Default x type sticking rear left caliper e brake
Finally got around to looking at why the ebrake is barely holding. Seems the d side bracket had seized. A couple pops with a hammer and loosening the t30 pivot bolt and it is now looser but doesn't want to return all the way. What happens if I take this apart on the back side anybody have a internal diagram? Cheapest I can find is 60 for one via rock auto would hate to buy one just for the e brake.
Old Aug 8, 2015 | 09:48 PM
Thermo's Avatar
Veteran: Navy
Trevor, having torn a few of the calipers apart, you can pull off that T-30 bolt and not have any issues. You will find a rubber cover under the lever and if you pull that off, you will see a shaft that goes into the caliper body. You can try adding some WD-40 or other similar product there to try and flush out the rust. But, from my experience, you need to either pull out the shaft and clean up the insides using a scouring pad and/or emery cloth or you will need to get yourself a new caliper and install that.
Unfortunately, I fought the e-brake on my X-Type. I was messing with one of the calipers about every year. I got to the point that I bought a rebuild kit and the special socket to pull the caliper apart. if you don't mind a "little" trip, I am an hour south of DC. I am sure I can get you taken care of in about an hour.
Old Aug 9, 2015 | 10:28 AM
Dr dome's Avatar
I have a good used one I would be happy to meet you save shipping , lets say 35 bucks for the caliper. let me know.
The Dr!
stanjag
Dec 29, 2024 08:26 PM
BrentGardner
29
Dec 16, 2024 12:13 AM
Spikepaga
Aug 30, 2015 12:59 PM
nelsonht
Aug 30, 2015 06:01 AM
hawianjim
Aug 29, 2015 07:23 PM
