X-type Transfer case
Old Aug 30, 2015 | 02:06 PM
FordPAGFanBoy's Avatar
Default X-type Transfer case
Hi Everyone,
I was wondering is everyone's transfer case loud? I replaced my tires, wheel bearings and still loud, my mechanic told me it is most likely my transfer case. I had the oil changed recently and it is still very loud. Car has about 54k miles on it.
Do i really have to replace it to make this awful humming go away?
Old Aug 30, 2015 | 02:09 PM
DPK's Avatar
DPK
It could be the Propeller shaft center support bearing going bad...that is a classic for making ufo sounds
To check; remove the shaft (driving on front wheels only) and if the sound goes away, then that's the culprit, if not, it could be the TC.
Old Aug 31, 2015 | 06:47 PM
Dr dome's Avatar
Sounds like the center bearing on the Drive shaft.
Old Sep 6, 2015 | 10:29 AM
Thanks everyone! I will investigate further. Any other ideas? I really do not want to replace my transfer case.
Old Sep 6, 2015 | 11:34 AM
astromorg's Avatar
Sorry DPK, but if you remove the prop shaft on a 2007MY AWD, you'll be going nowhere! Unless you can lock the disconnected output from the transfer box. No viscous coupling since and including, MY2004
Old Sep 6, 2015 | 11:47 AM
billbjork's Avatar
Default noise
Pin it down this way: loud crying sound at about 20/25 mph either accelerating or decelerating but not a road speed: It's the center drive shaft bearing,( worse in cold weather):i
Low speed moaning (sounds like a truck) goes away above 40mph: probably transfer case or trany. Mine has been doing it for 10 years after flushes and has never changed (doesn't seem to matter what temperature it is outside).
Humming, buzzing sound above 50 mph probably a wheel bearing.
Clicking, or buzzing when turning: Axle (CVC joint)
Grinding or buzzing when stopping: brake rotor.
Any loud noise from the passenger side: Probably the wife. LOL
silkcat
Jan 18, 2025 04:29 AM
vwbusbits
Oct 13, 2015 03:43 AM
vwbusbits
Oct 1, 2015 01:17 AM
Amberlinder541
Sep 26, 2015 01:10 PM
mrplow58
Sep 15, 2015 09:58 PM
