X-Type water hoses
Old Dec 30, 2015 | 02:05 PM
Bash's Avatar
Thumbs up X-Type water hoses
Hi,to all the jag members...I need some advice and help on how to replace all
my water hoses on a jaguar x type..and all of you have a great and prosperous new year.
thanx a mill.
regards
BASH
Old Dec 30, 2015 | 04:16 PM
Bash,
I've moved your question from General Tech Help to X-Type forum. This is the place to post tech questions about your model.
Old May 14, 2016 | 10:17 PM
Thang Nguyen's Avatar
Go to Harbor Freight buy a set of big and long needle nose pliers for remove the ring clams, to be easier to remove the hoses, get a chopstick carve one end flat about 3/16 thick, dip it in the dish soap, insert around inside between the rubber hose and metal pipe, it make easier to pull the hose out, or just cut them off because you going to replace them any way.
Old May 15, 2016 | 08:37 AM
avern1's Avatar
I think your first step should be to go to the advertisement link for SNG Barratt and download their catalog. The cooling section will give you a look at all of the hoses involved in the cooling system.
When you are renewing the hoses make sure to renew the thermostat as well. When removing hoses around the expansion DO NOT pull, twist or pry them off. Just take a razor knife and slice thru the rubber and remove the hoses. You do not want to risk breaking the spigots coming out of the tank.
A few of the hoses come as metal tube/hose assemblies. It isn't worth the trouble to try and reuse the tube and only replace the hose. Go with the assembly.
Smudge78
Jan 27, 2016 06:25 AM
80sRule
Jan 22, 2016 12:16 PM
Jimmy James 905
Jan 6, 2016 11:02 AM
sjyokel
Dec 30, 2015 07:12 AM
