X400 - replaced water pump, now fans don't work
Old Mar 26, 2020 | 10:40 AM
pinchas770's Avatar
Default X400 - replaced water pump, now fans don't work
Hi All
My 2007 X-Type 3.0, overheated, due to the water pump failing.
The battery was disconnected, prior to the mechanic, fitting it.
When the car was restarted to fill the cooling system, the fan immediately went on, while the car was really cold, and then
went off after a few minutes.
Now the fans don't work at all, even when the air- conditioner is switched on.
Please help.
Warm Regards
Peter Onay
Johannesburg
Old Mar 29, 2020 | 09:19 AM
abonano's Avatar
Check electrical connections
Old Mar 30, 2020 | 05:09 AM
pinchas770's Avatar
Many Thanks
Will do.
Warm Regards
Old Mar 30, 2020 | 05:20 AM
Originally Posted by pinchas770
My 2007 X-Type 3.0, overheated, due to the water pump failing. .....
Peter,
I've moved your question from General Tech Help to X-Type forum. This is the place to post technical questions about your model.
Old Mar 31, 2020 | 03:46 AM
pinchas770's Avatar
Thanks Graham
Really appreciate it
Warm Regards
Peter Onay
Old Apr 1, 2020 | 12:09 PM
gkubrak's Avatar
Sounds like a bad module.
Disconnect the connector to the fan and try spinning the fans manually to make sure they are not seized up and can spin freely.
If you have a multi-meter you can do resistance tests on the circuit. You may be able to rig a power supply to the fans just to make sure they turn.
If all that is good, I would replace the fan control module. Stay away from the aftermarket Chinese ones, as I have heard they do not work (I had 1 and it did not work). If you can get an OEM module that would be ideal.
Busa196
Jan 13, 2025 04:33 AM
Jag4me2
Jan 28, 2019 04:21 PM
starstream
XJ40 ( XJ81 )
Aug 14, 2017 09:11 PM
ctlikon
Apr 16, 2017 08:02 AM
