Xtype/CrownVic Same bolt pattern?
Old Sep 20, 2009 | 03:21 PM
Jessy's Avatar
Question Xtype/CrownVic Same bolt pattern?
Hi forum hope all is well
Well as we all know that winter is approaching and traction is a big issue with the northern hemisphere and the issue that comes along with that are a good set of winter tires. Well i have the winter tire part covered i have SnowLions. I was doing some research and came across a site where all of the makes and models are listed with the bolt patterns and from what i know the bolt pattren for an 04 xtype is 5x108 and also on the site it said that a crown vics bolt is 5x108. Now i am not for sure for sure on the bolt pattren for my 04 xtype if it is 5x108 and ive cheked local tire shops and they wont tell me so is the bolt pattren 5x108?? if so its alll good: So if some one can confirm the bolt pattren ud save me alot of time and money thanx
Old Sep 20, 2009 | 03:40 PM
StrateLoss's Avatar
go to tirerack.com , they list that information
Old Sep 20, 2009 | 03:53 PM
Thermo's Avatar
Veteran: Navy
Jessy, while the bolt pattern is 5x108 for you X-type, you need to also look at the offset of the rim. You get too different of an offset and you will end up with rubbing issues and possible excessive bearing/hub wear.
Doing a quick look, I came up with a bolt pattern of 5x114, not 5x108 for the crown vic. The offsets are fairly close for a 2003-2008 Vic. Not many changes have been made to the cars over time. I even did a quick look of Crown Vic from 1995 to 2008 and all use the 5x114 bolt pattern. So, I would be double checking the rims that you are looking to buy. Also note that the newer Vics have a useable offset, but the older ones do not. So, what year Crown Vic are you looking at?
Old Sep 20, 2009 | 04:42 PM
StrateLoss's Avatar
brown vics and lincolns share a bolt pattern. which is 5x4.5 (5x114.3)
knowing this i should have answered it.
many japanese cars have this pattern as well, jaguars dont.
older vics have offsets in the +50's which is no good, you wont rub on an 8inch rim, but youll have sunken wheels and a thinner trac + bad hanlding.
you need anything lower then a +40 offset , also the wider wheel you go the lower positive offset youll need.
if the rims from the crown vic are free you can get 20mm spacers that have bolt pattern adapters and are hubcentric. they can get expensive.
if your buying the wheels, its simple > dont.
-vee
Old Sep 23, 2009 | 01:36 PM
91stealthes's Avatar
I may still be able to get you 17" 7 flute wheels with some curb rash and summer tires cheap...would need to see if they are still available though.
I think they were $100 or $125 each.
Old Sep 23, 2009 | 02:58 PM
The Chris X's Avatar
Crown Vic wheels on an X type? That's just wrong on so many levels.
Old Oct 6, 2009 | 09:06 PM
Jessy's Avatar
91stealths where abouts are you located? i got 17s and thats what um looken for.
Does anybody else know what other car shares the same bolt pattern and the bolt pattern is 5x108??
Old Oct 7, 2009 | 11:53 AM
StrateLoss's Avatar
type 5x108 into ebay motors wheels and tires subsection and youll get results.
Johnken
Apr 8, 2018 10:21 AM
tomkilner
Oct 9, 2015 07:10 AM
Johncy2000
Oct 2, 2015 01:05 AM
baskervillema
Oct 1, 2015 06:43 PM
XJ8JR
Sep 29, 2015 06:59 PM
