XKR body processor module
Old Jul 8, 2016 | 04:30 AM
bobskey's Avatar
Default XKR body processor module
hi have problem with body processor car start fitted body processor LJG2500CB which is same number as one taken off car starts runs fine but unable to open roof must be off a coupe it says programmable on unit can this be programmed for a convertible if so were to get it done
bobskey
________
2005 XKR (added by GGG)
Old Jul 8, 2016 | 04:51 AM
Datsports's Avatar
it will have to be dealer programmed .
Old Jul 8, 2016 | 05:11 AM
bobskey,
You've posted this same question in at least three different forums here:
I've moved this latest one from General Tech Help to XK8/XKR forum. Members here with the same model will be able to help.
In previous posts you wrote you'd obtained a BPM (Body Processor Module) from Eurojag and the car was with your 'diagnostics man'. You also didn't understand the different part numbers.
To answer your question about the part numbers. LJG2500CA was fitted up to VIN A38671 and LJG2500CB was fitted from VIN A38672 onwards. The same programmable modules were fitted to both Coupe and Convertible.
I've used Eurojag since they first opened and have always found them to be knowledgeable, helpful and reliable. If you quoted the correct VIN, I'd be amazed if they supplied an incompatible BPM.
Presumably your 'diagnostics man' doesn't have the equipment or ability to interrogate and program modules?
Old Jul 24, 2016 | 11:47 AM
bobskey's Avatar
got it going at last it has a new body processor,key barrel key receiver instrument panel and j switch only thing unable to open roof due to processor being of a coupe have now got it re-programmed and working ok don't want this problem again what is best thing to do when standing over winter have always just connected battery charger after battery has gone flat
did not work this time .Is it better to remove battery and charge of car or buy one of these ctek chargers
bobskey
Old Jul 24, 2016 | 12:18 PM
Ctek is the way to go.
Old Jul 24, 2016 | 12:47 PM
RJ237's Avatar
+1 ctek. Leaving the battery disconnected sometimes results if modules losing memory as does leaving battery connected and allowing it to discharge. A good way to lose the battery,also.
Rey
Apr 9, 2016 09:52 AM
o2manyfish
Apr 4, 2016 11:13 AM
434MHz
Mar 27, 2016 06:51 PM
hub61
UK & Eire
Mar 26, 2016 11:08 AM
stevepaa
Mar 24, 2016 10:33 PM
