XE ( X760 ) 2015 -
Brake Pads
Old Jul 16, 2017 | 07:12 PM
F1FANATC's Avatar
Default Brake Pads
I recently took my Jag XE for a track day. The car was a blast to drive spirited, but over a couple of laps I noticed some serious brake fade. So much so, that my pedal is longer for my everyday driving. I'm surprised at this as I expected the OEM pads to handle some hustle. Has anyone purchased some more "track ready" pads?
Old Jul 16, 2017 | 07:59 PM
Mikey's Avatar
Sounds like glazed friction surfaces not 'brake fade'.
Old Jul 16, 2017 | 10:44 PM
F1FANATC's Avatar
So I'll be replacing them I assume?
Old Jul 17, 2017 | 08:19 AM
Mikey's Avatar
Any local garage can deglaze rotors for a couple of bucks each. They can also see if the pads are worth saving.
Old Jul 17, 2017 | 08:29 AM
F1FANATC's Avatar
Thanks for he reply. What options do you think would help reduce this in future use? Do you think a performance brake fluid would help? Eliminating track days isn't an option. Lol
Old Jul 17, 2017 | 09:17 AM
mosesbotbol's Avatar
I would do pads, fluid, and install speed bleeders. Does EBC make a pad for our car?
Old Jul 17, 2017 | 09:58 AM
Mikey's Avatar
What you've experienced (again) is nothing to do with brake fade. Fluid played no part in the pad/rotor glazing- if in fact that's the issue.
Please stop by the new members area to post an intro and also update your sig with relevant detail when you have a chance.
Old Jul 17, 2017 | 01:17 PM
F1FANATC's Avatar
Update on Brakes.
Got a local garage to have a quick look at my issue. It is my brake pads, and they are worn. Which is disappointing to say the least.
Old Jul 19, 2017 | 02:45 PM
Demetre Gvaramia's Avatar
Update on Brakes.
Got a local garage to have a quick look at my issue. It is my brake pads, and they are worn. Which is disappointing, to say the least.
Try more aggressive trail-braking and downshifting next time to conserve the life of your pads.
OEM pads are usually quite sub-par in performance. I have 15K miles and can feel a noticeable decrease in braking performance even though I have not done any trackdays.
Old Jul 19, 2017 | 03:05 PM
I believe Jaguar has changed pad over the years as they got knocked on initial quality score due to customers complaining about brake dust. My XK would dust just leaving the drive way. Similarly with BMW and Audi. Not sure why that was a knock at Jaguar.
My hunch is they went to a less dusty pad, but some braking performance or wear is a side effect. That is to say I am quite surprised at how little dust the XE produces (in a good way), but not so keen on the overall braking performance.
Compare the XE to a Ghibli and braking difference is just tremendous. Ghibli is another league.
