XE ( X760 ) 2015 -
In Control doesn't work with IOS 13?
Old Sep 24, 2019 | 05:38 PM
oldpunk's Avatar
Default In Control doesn't work with IOS 13?
Anyone else update their iphone to IOS 13 and now In Control apps no longer works? Is it just me? The Remote app works, but not InControl. I can't listen to Spotify anymore
Old Sep 25, 2019 | 06:58 AM
DJS's Avatar
DJS
Wouldn’t surprise me. I haven’t gotten around to installing any apps, but I do have CarPlay - I’ll have to try that. But I’m driving the F-type while we’re having nice fall weather here. The F-type started dropping the BT connection (usually reconnecting on its own), likely after a previous update. Don’t think that’s improved.
I’ve noticed worse battery life on my iPhone SE with iOS 13, but that’s it so far.
Old Sep 25, 2019 | 08:53 AM
mosesbotbol's Avatar
This car is a pain with pairing and updates on the iPhone.
Old Sep 25, 2019 | 10:00 AM
Jer025's Avatar
I just posted the same thing in the Smartphone Sticky. It will connect then drop Bluetooth, then repeat the cycle.
New to Jaguar, have they released firmware updates in the past for new IOS releases?
Old Sep 26, 2019 | 05:02 PM
jsavner's Avatar
Default BT Issues
Android users just went through this ordeal. We are now having to run a separate app that manages the BT connection and something to do with contacts. With the app running on the phone, all is well. This was the culprit as to why we were getting similar things happening (phone would connect and then disconnect after a few seconds or minute and repeat). It's possible that Apple did something similar and removed some protocol that the system is looking for. Look up the issue with Android 9 and Bluetooth and you'll see the annoyance this caused. Saw on a Samsung thread from the EU that Jag is releasing an update in the next month or so that is supposed to fix the Android issues. Maybe it will help with IOS too.
Assuming you have removed the connection from the phone and car and repaired?
To test the theory above, try not having your contacts synced via BT. If you get a stable connection then it maybe the same issue.
Good luck!
Old Oct 7, 2019 | 11:11 AM
John231's Avatar
Just updated IOS 13.1.2 Every thing back the way it was In Control working
Burt Gummer
Jan 31, 2022 10:40 AM
Shane O' Donovan
Feb 22, 2018 04:44 PM
coffeerich44
XE ( X760 )
Mar 3, 2017 03:37 PM
ScoopusMaximus
Mar 28, 2015 06:35 AM
mshedden
Feb 20, 2015 10:38 PM
