XE ( X760 ) 2015 -
CTEK 3300 Charger
Old Mar 30, 2019 | 09:15 PM
Peter HL's Avatar
Default CTEK 3300 Charger
I have been using my CTEK 3300 with the cigarette lighter attachment to charge my Aston Martin DB9 with great effect, I have now just purchased a Jag XE and was wondering if I can use the charger for the jag, via the 12v port in the trunk, or do I actually need to connect the charger up to the battery?
Old Mar 31, 2019 | 09:00 AM
martind511's Avatar
It depends if this the dedicated charging socket or a normal 12v socket. If I remember correctly the dedicated charging socket is a little smaller than a std 12v socket.
if you don’t have this then suggest using crocodile clips to charge via the terminals under the bonnet (hood). I ended up fitting a ctek charging socket in the boot (trunk) which shows the battery charging state.
Old Mar 31, 2019 | 09:52 AM
Peter HL's Avatar
Thanks, so if I understand what you are saying it means if the charging socket fits the plug I will be OK or are you saying something different?
Old Mar 31, 2019 | 11:07 AM
martind511's Avatar
It depends on what plug is on your charger - I just know in the UK ou can specify a charging socket if you buy the CTEK charger. I will see if I can get a picture of the socket
Old Mar 31, 2019 | 08:55 PM
mosesbotbol's Avatar
...I have now just purchased a Jag XE and was wondering if I can use the charger for the jag, via the 12v port in the trunk...
Yes you can.
richzak
Jan 19, 2018 07:03 AM
jaguny
Dec 22, 2016 04:59 PM
bocatrip
Mar 28, 2014 07:03 PM
chazaroo
Feb 10, 2014 07:39 AM
RCG
Oct 6, 2013 08:13 PM
