XE ( X760 ) 2015 -
Door closing - rattle
Old Mar 6, 2017 | 10:11 PM
RaffiNJ's Avatar
Default Door closing - rattle
Does anyone have any rattling noise closing the door? my driver side front door makes a rattle when I close it. Since it was not aligned properly to begin with (I showed pictures in another thread) I thought it was related but the noise is starting to annoy me more then I would like and I started to fish around. I tried closing all other doors and do not hear this noise. Today I started to bang slightly on the inside panels just to see if its the door or maybe panel and was able to replicate a similar noise banging next to the door handle. To make it more interesting there is a similar noise on passenger side when I bang in the same general area but its not as loud and there is no noise from closing the door. I know it maybe nonsense to some but it is very annoying to me and I feel like I should ask the dealer to fix this. After my last visit I feel like they will just say there is nothing they can do about it. I could try recording it but not sure how it would come out in a video.
Old Mar 7, 2017 | 09:11 AM
NewLester de Rocin's Avatar
No rattle.
I had a bad habit of slamming doors and trunk (way harder than I needed to) when I first got the XE.
If a rattle was normal in the door, I'd be hearing it by now.
I know there are a quite a few interesting electronic modules mounted inside some of the door assemblies. There's always a theory that a cable or unit might be tapping something else and causing that rattle.
But that's just theory...
Old Mar 9, 2017 | 08:38 PM
JBzXJ40's Avatar
I have come across quite a few rattles in the drivers door when closing, even closing softly, this was mostly on the XF, however the XE is a similar set up. It was the cables on the window regulator that were rattling against each other, I just wrapped a piece of foam around it, noise gone. It could be something else, so you may need to take the door panel off and have a look.
