XE ( X760 ) 2015 -
Help with smashed rear differential
Old Apr 2, 2019 | 04:09 PM
geojonesiv's Avatar
Default Help with smashed rear differential
I just bought a 2017 XE 25t from a salvage auction. Car looks great but must have gone off a jump or something because the rear diff is crushed. I'm trying to pull it out so I can see what it is and get a new one, however, I can't get the rear axles out. I bought a pdf repair manual, but it is garbage, just has drawings and shows the axles just pulling out after you pivot the rear bearing assembly down out of the way. But mine won't pull back out. I can't find any clips or any way to get it loose.
Old Apr 3, 2019 | 08:47 PM
Stwsam's Avatar
Can you not remove the suspension knuckle and work inward to the diff?
Old Apr 3, 2019 | 09:21 PM
geojonesiv's Avatar
I can't get the axle out of the knuckle or out of the diff. Do you know how to remove it? The PDF manual a bought just shows it pulling out from the back but I can't get it to.
Old Apr 4, 2019 | 05:58 AM
Stwsam's Avatar
I was wondering to you fully unbolted the knuckle would everything not pull outward as possible your axles are either bent or just too torqued to move. By dropping the knuckle the axle would free up.
Old Apr 4, 2019 | 08:11 AM
geojonesiv's Avatar
It is loose enough now I think, when I pull the knuckle it pivots downward but the axle stops it. The “instructions” say to pivot it down and the axle will automatically pull out the back.
Old Apr 4, 2019 | 08:56 PM
Stwsam's Avatar
Assuming car has no significant damage. I would fully remove knuckle.
Old Apr 5, 2019 | 04:59 PM
geojonesiv's Avatar
I've removed all the bolts from the knuckle, it can flop around more now. The issue remains, the axle won't pull out of the back.
xFyght
Oct 22, 2022 05:13 PM
unders
Aug 3, 2013 07:44 PM
clubairth1
42
Feb 25, 2012 12:49 PM
ghettomike
Dec 1, 2010 09:30 PM
damianpenney
Feb 15, 2010 12:27 AM
