XE ( X760 ) 2015 -
How to remove Center Console side panels and outside air intake side vents
Old Apr 4, 2018 | 09:24 AM
Jag2018's Avatar
Default How to remove Center Console side panels and outside air intake side vents
Hello everyone,
I am thinking to plasti dip a few interior and exterior finishings to have a better / different finish than the stock (some what unsatisfactory) finish we have on the MY 2017 XE S.
Has any one removed the Center console side Panels, exterior side air vents or rear view mirror caps.....
would really appriciate the procedure how to do it ..
Would be very helpful if one of you ( with the download access of course) could download these docs from TOPix and share it. Would be a starting point as a guide...
tried searching the Forum but could find anything thats completely relevent..
Thanks guys
Phani
Old Apr 4, 2018 | 09:56 AM
Eric325ci's Avatar
If you subscribe to TOPIx (https://topix.jaguar.jlrext.com/topix/user/loginForm) there are comprehensive manuals in taking apart the car.
Best of luck
Old Apr 4, 2018 | 10:11 AM
Jag2018's Avatar
Thanks Eric325ci !!
I am registered with TOPIx... but I did not know that I have Access to view the documents.. Will try to find the guides and see how it goes..
Old Apr 5, 2018 | 07:18 AM
Jag2018's Avatar
@Eric325ci, Unfortuantely the documents that would help in removing the Center console side Panels are not available to view/download from TOPIx. I guess they are under Workshop Manual section or some other which are not accessble..
Old Apr 9, 2018 | 04:47 AM
Kevin Zhu's Avatar
Originally Posted by Jag2018
Hello everyone,
Thanks guys
Phani
Hey Phani,
I’m actually in the process of vinyl wrapping my XE. In regards the the mirror caps, just pull from the bottom and wiggle it out with medium to high pressure. Snaps right back on, bottom first. To get the panel off, there is a hidden TORX bolt, which I’m looking for the right size screwdriver... let me know if you figure that out. Hopefully this helps, and good luck.
-Zhu
Old Apr 9, 2018 | 10:49 AM
Jag2018's Avatar
Originally Posted by Kevin Zhu
Hey Phani,
-Zhu
Thanks Kevin, Will try as you suggested for the mirror caps.
Do you know the Location of the torx bolt on the Panel ?
Phani
SansuiMan
Jan 27, 2018 12:06 PM
RedRider48
Jul 12, 2017 12:08 AM
JustNiz
Jan 24, 2017 07:09 PM
xjrjag
Jul 9, 2015 01:41 PM
Ggraddy
May 5, 2015 01:56 AM
