XE ( X760 ) 2015 -
Loose roof antenna
Old Apr 10, 2018 | 12:32 AM
keith100's Avatar
Default Loose roof antenna
So today I waxed the car. Not sure if clearcoat finishes even need waxing but it makes me feel very virtuous to give a coat of wax once a year.
Anyway while buffing the roof I noticed that the “shark fin” antenna was loose.
I don't really want a tech to rip out the roof liner, but concerned water will get in and mess the electrics and stain the roof liner. My last car had a similar antenna, but it had a rubber gasket to seal the joint tightly. I can't see one on the Jag. Even if it was bolted tightly, I would think it would still need a gasket to be watertight.
Does anyone on know if this is normal? I wonder if someone would be kind enough to check their XE antenna and let me know if its loose or has a gasket.
Thanks in advance
Old Apr 10, 2018 | 04:01 PM
Fraser Mitchell's Avatar
Mine is slightly loose on my X350, I noticed a gap towards the rear last year, but with our recent dreadful winter, I have yet to look at it, but like you, I'm reluctant to let a technician "loose" on it. I thought a squeeze of silicone sealant might be my best option, but I'll get it assessed at the next service.I have no water leaks into the car, BTW.
Old Apr 11, 2018 | 01:13 PM
Kevin Zhu's Avatar
My antenna can move slightly less than 1 mm - this is relatively normal. I had it removed and reinstalled for a wrap job.
Old Apr 11, 2018 | 06:46 PM
keith100's Avatar
Thanks Kevin
My antenna moves a bit more sideways, plus up and down at the rear.
Do you know how it comes off?
Old Apr 12, 2018 | 04:00 AM
Kevin Zhu's Avatar
Originally Posted by keith100
Thanks Kevin
annoyingly enough, the entire interior header has to be removed.
Old Apr 12, 2018 | 07:58 AM
keith100's Avatar
That's what I feared,
Did the replacement go well?
How's the wrap going?
Old Apr 12, 2018 | 09:23 AM
..... Not sure if clearcoat finishes even need waxing but it makes me feel very virtuous to give a coat of wax once a year. .....
They definitely do. It's the 'sacrificial layer' between your paint and the elements. Not many waxes will survive beyond half a dozen washes.
I keep my cars clean but am nowhere remotely near being a fanatic and mine get waxed three or four times a year.
Old May 5, 2018 | 05:29 PM
keith100's Avatar
Well eventually I booked the car into the dealer (3 weeks to get a loaner). The existing antenna is loose. The tech found he couldn't tighten it but couldn't see why, so a new fin cover is needed. So worst case scenario - 3-4 weeks delivery from UK. Not good.
Meantime I'm stuck with a 25T f pace, which is seriously damaging to the image!
mat32essex
Aug 17, 2015 11:23 AM
coudamau
Jan 3, 2014 12:04 PM
Spikepaga
Sep 13, 2013 11:35 PM
artstar
Aug 9, 2012 04:14 AM
Oct 28, 2010 11:12 AM
