XE ( X760 ) 2015 -
Powering devices via an XE
Old Jan 1, 2018 | 03:36 PM
DavidCH's Avatar
Default Powering devices via an XE
Hi, I recently brought home a 2018 XE and want to keep it looking its best, so I got a Porter Cable random orbit polisher (to use to buff out scratches and apply wax). I currently live in an apartment with no garage or lot parking. (But don't worry: I rent half of a private garage, where I store the car most of the time.) So I don't have easy access to a building's AC wall outlets. I'd like to use the XE itself to power the polisher.
So far I've tried using a 1000W inverter (and hooked it up to the XE's battery via the under-hood connections). It worked fine powering a blower that I use to help dry the car after washing it, but when I tried the polisher (even at the lowest speed), it was barely able to run. (The polisher looked like it wasn't getting enough current/amps. The car's engine was running, and the inverter's cables/cords were not overheating.) I probably should have figured this would happen, so now I'm looking for other options. One possibility may be getting a portable, rechargeable battery/inverter combination (like this one). By the way, I'm trying to avoid modifying the XE itself (or spending a small fortune).
Any suggestions would be appreciated.
David
bfinnega
May 8, 2017 01:38 PM
XJR 308
Dec 3, 2016 03:47 PM
talulah
Oct 24, 2014 08:46 AM
bahnjee
Apr 6, 2012 10:25 AM
