XE ( X760 ) 2015 -
Project 8 walk around
Old Dec 22, 2017 | 03:33 AM
dave_Sw1's Avatar
Default Project 8 walk around
Saw one in the flesh at laguna Seca, gorgeous
Old Dec 22, 2017 | 10:36 AM
mosesbotbol's Avatar
I would've expected it to have fancier rear calipers. Just look like the stock ones painted.
Old Dec 22, 2017 | 11:14 AM
zach05855's Avatar
From my spec sheet.
BRAKES, WHEELS & TIRES
Carbon Ceramic Braking System
Project 8 offers the latest Carbon Ceramic Braking (CCB) technology as standard. Consisting of new 6 piston front calipers with 400mm Carbon Ceramic discs and 396mm Carbon Ceramic discs for the rear, Project 8 delivers enhanced levels of sustained braking performance under demanding conditions. To best utilize the high performance Carbon Ceramic Braking System, Project 8 will employ a synthetic racing brake fluid which has an exceptionally high dry boiling point, making it ideal for use under extreme braking conditions such as those experienced on track.
Old Dec 22, 2017 | 12:36 PM
Originally Posted by zach05855
From my spec sheet.
They could it be the regular XE rear caliper with carbon disks and pads, no? Looking at the F Type SVR, the rear calipers are what I would expect on the Project 8. That is not what is in the OP's linked video.
Could it be the production Project 8 will have the SVR's brakes?
Old Dec 22, 2017 | 07:50 PM
alphakinase's Avatar
You're right mosesbotbol, those rear calipers do look a little small! Odd!
Old Dec 22, 2017 | 11:04 PM
zach05855's Avatar
This is not a final production car. The actual final production car will probably have different components. This car is likely just for the show circuit.
Old Dec 22, 2017 | 11:14 PM
zach05855's Avatar
There are still a lot of TBD for this car.
TECHNICAL SPECIFICATIONS
SPECIFICATIONS XE SV PROJECT 8
Engine Capacity (cc) 5,000
Configuration V8 Supercharged
Power (hp @ rpm) 592 @ 6,500
Torque (lb-ft @ rpm) 516 @ 3,500 - 5,000
Valves per cylinder 4
Compression ratio TBD
Bore/stroke (mm) TBD
Fuel tank capacity (L) 63
Final drive ratio TBD
Suspension - front Double Wishbones, Adjustable Coil Springs, CVD Dampers
Suspension - rear Integral Link, Adjustable Coil springs, CVD Dampers
Brake Type - front/rear
Carbon Ceramic Disc Six-Piston Caliper /
Carbon Ceramic Disc Single Piston Caliper
Brakes - diameter front/rear (mm) 400 / 369
0-100 km/h (sec) Target of 3.7 (TBC)
Top speed (km/h) 322
Length (mm) 4,713
Width (excl mirrors) (mm) 1,954
Width (incl mirrors) (mm) 2,075
Overall Height (mm) 1,436 / 1,421 (Track Mode)
Wheelbase (mm) 2,835
Front track (mm) TBD
Rear track (mm) TBD
Turning circle - curb to curb (m) TBD
Curb Weight (kg) TBD
Leg room - front (mm) 1,055
Leg room - rear (mm) 889
Head room - front (mm) 970
Head room - rear (mm) 947
Shoulder room - front (mm) 1,442
Shoulder room - rear (mm) 1,389
Trunk space (L) with tire repair kit 450
Johnny Mayday
I-Pace EV
Jul 27, 2017 05:53 PM
powerhouse
Jan 6, 2017 07:07 PM
