XE ( X760 ) 2015 -
Rear brake cylinder fell out of boot
Old Nov 18, 2023 | 11:59 AM
Micah Bernard's Avatar
Default Rear brake cylinder fell out of boot
I no I should have researched first. Released the parking brake but pressing button in the car which allowed me to remove caliper passenger side. While holding in my hand just looking at stuff I tilted downward and the cylinder fell out along with the other round threaded piece. Side note that piece has a million tiny springs that went everywhere 🤦🏻‍♂️. My question is did I cause myself to have to purchase a new cylinder??
Old Nov 18, 2023 | 02:14 PM
Fraser Mitchell's Avatar
So what button is this that you pressed ?
Old Nov 18, 2023 | 02:21 PM
dangoesfast's Avatar
You're the second person in a couple of months who's pulled their caliper apart and jumped straight to buying a new one instead of putting it back together. Do some googling for a diagram, and carefully reassemble it.
When it's all done, pay a professional to give it a safety check. Brake failure is no joke, don't trust your own work if you don't know what you're doing.
Old Nov 20, 2023 | 08:16 AM
chrisjp's Avatar
I assume you're talking about releasing the electric parking brake (EPB) to enable the rear brake caliper to be removed? If so, if you didn't put the EPB into service mode then I think there is the likeliehood that it actuated while you were looking at the caliper - and this is what caused the cylinder to "fall out".
There's a specific sequence of pressing and releasing the EPB dashboard switch while flooring the accelerator pedal to put the EPB into service mode. This ensures it stays off and doesn't spontaneously activate!
This sequence is detailed in the workshop manual but, if you need it, I might be able to dig out my own notes on rear brake caliper servicing that I put together a while ago.
Old Nov 20, 2023 | 08:30 AM
Thanks for the info I was able to put everything back together cylinder back in the boot pads put on. Then I put it in maintenance mode.
Old Nov 20, 2023 | 08:43 AM
But if you have time and it’s not a big deal to find the specs on it I would appreciate it.
Old Nov 20, 2023 | 10:29 AM
chrisjp's Avatar
Not the specs I'm afraid, but a note I put together on how I went about replacing the rear brake pads on my XE
It's attached
Old Nov 20, 2023 | 10:32 AM
Thank ya man for taking the time to do that
Old Mar 3, 2024 | 04:09 PM
janosh white's Avatar
How do you put it back together? I just did the same thing
italcarnut
Sep 12, 2023 07:55 AM
AndreasXJS
Aug 5, 2023 09:38 AM
yarpos
Apr 1, 2023 04:43 PM
osyris
Aug 10, 2022 02:49 AM
my420
Apr 23, 2021 11:18 AM
