Brake master cylinder
Old Aug 29, 2023 | 02:36 PM
italcarnut's Avatar
Default Brake master cylinder
Hey fellas. Dose anyone know where I can get a remanufactured brake master cylinder? I have exhausted all known supply houses. The others want a fortune for one. Was that unit used on any other cars out there. Parts are getting hard to find. Or an another note, does a rebuild kit exist?
Old Aug 31, 2023 | 01:39 PM
clubairth1's Avatar
Community Influencer
Maybe list your car details in case all the MC's are not the same?
Old Sep 1, 2023 | 06:49 AM
italcarnut's Avatar
Sure. The protagonist is a 1995 Jaguar XJ6 base model. So far it seems I will be ending up at a junk yard.
Old Sep 2, 2023 | 10:17 AM
clubairth1's Avatar
Well believe it or not but O'reilly's lists two different ones! Cheap too at $200-$150.
Are you OK with a reman. one? Do you have yours out of the car? I ask because I would for sure take it with you if you do order one. Just to make sure those listings are correct!
Brake Master Cylinder
Here is a new and used one. New is $1000+!! I "think" the Jaguar part number is JLM12080 but check as it changes with your VIN.
Master Cylinder
I can't find any rebuild kits?
Old Sep 2, 2023 | 11:37 AM
italcarnut's Avatar
Yes, a few years ago I bought one from Oreillys for my wife '96 VDP. Still works great. I called them and they said they can no longer get them. I called Cardone A1 and was told they got out the the master cylinder reman buisness a year ago.
Old Sep 11, 2023 | 10:32 AM
italcarnut's Avatar
Well, after all that the problem was not the master cylinder, but a rusted out hardline by the left rear wheel. I guess I should replace both of them I also noticed lots of rust on the fuel line going to the filter. What a pain! I still will be looking for a master cylinder since they are unobtainable.
Old Sep 12, 2023 | 07:55 AM
clubairth1's Avatar
That's a least a cheaper and simpler repair! Can't argue with that!
I was glad when the car manufacturer's switched to plastic fuel lines too.
AndreasXJS
Aug 5, 2023 09:38 AM
yarpos
Apr 1, 2023 04:43 PM
stasha
XK120 XK140 XK150
Nov 27, 2022 02:06 PM
falderfer
E type ( XK-E )
May 21, 2021 11:53 AM
Tasng4
Mark V - X 420G
Jul 1, 2019 05:04 AM
