XE ( X760 ) 2015 -
Reversing camera doesn't always work XE 2017
Old May 9, 2023 | 07:14 AM
G.Kelly1's Avatar
Default Reversing camera doesn't always work XE 2017
Sometimes when reversing the reversing sensor screen shows up instead of the camera, and even if I push the camera button it still won't work. But could go back to the car 10 minutes later and it will be fine. Any thoughts?
Old Aug 31, 2023 | 11:02 AM
Alain321's Avatar
I had the same problem as you it is the electric cable which is cut when opening the trunk it is fixed to the bodywork with an elastic clip each time the is opened the cable pulls and breaks over time it is a jaguar fault xe you have to cut it resoldered I'd this and it works perfectly
Old Dec 28, 2025 | 05:52 AM
Bouba40's Avatar
Bonjour, pourrais-tu me dire ou ce situe exactement ce câble s'il te plaît
[QUOTE=Alain321;2675005]J'avais le même problème que vous. C'est le câble électrique qui se coupe à l'ouverture du coffre. Il est fixé à la carrosserie par un clip élastique ; à chaque ouverture, le câble tire et finit par se casser. C'est un défaut de fabrication chez Jaguar : il faut le couper, le ressouder. Je l'ai fait et ça fonctionne parfaitement.[/QUOTE
Old Jan 12, 2026 | 08:02 AM
RoverJoe's Avatar
Community Influencer
This became a recall campaign, at least in the US market.
Trent Lucas
Jun 6, 2021 06:10 PM
nicpy
XE ( X760 )
May 22, 2021 12:21 AM
JustBlessed
XE ( X760 )
May 21, 2017 02:57 PM
CRS 123
Feb 7, 2017 11:03 AM
triplekg
Nov 12, 2016 11:19 AM
