XE ( X760 ) 2015 -
XE Wheel Dimensions
Old Aug 29, 2016 | 10:28 AM
mosesbotbol's Avatar
Default XE Wheel Dimensions
Does the XE share the same wheel as the XF? Are the offset's the same? If I were to look for 2nd set of wheels from Jaguar, which models would be the same if not XF?
There's not much online for XE specific wheels (for used or like new on EBay, etc...). Figured XF or XJ would be better off. Just want OEM's...
Old Aug 29, 2016 | 11:12 AM
stever_51's Avatar
You can check here :-
Jaguar XE 2017 - Wheel & Tire Sizes, PCD, Offset and Rims specs - Wheel-Size.com
and here
Jaguar XF 2017 - Wheel & Tire Sizes, PCD, Offset and Rims specs - Wheel-Size.com
There is a much wider choice for OEM rims in the UK. best view from the UK configurator
UK Configurator
There are a fair few filtering through to UK eBay, some do dispatch worldwide - may be worth considering now that post Brexit the exchange rate for the pound is measured in chewing gum wrappers.
Old Aug 29, 2016 | 02:39 PM
Mulmur's Avatar
I have purchased Jaguar wheels from 'Coventry' and they are made to fit the various jaguar models .. they have a website.
Lawrence
Alli Quinninho
Dec 22, 2020 03:00 AM
PaulParanoia
Apr 12, 2016 05:42 AM
Cam99
May 3, 2010 12:13 PM
XType750
Jan 29, 2007 08:48 PM
Oct 15, 2005 10:11 PM
