XF (X260) 2015 onwards
09 jaguar xf supercharged (won't go into any gear)
Old Mar 5, 2018 | 08:35 PM
gextreme's Avatar
Exclamation 09 jaguar xf supercharged (won't go into any gear)
i have a 09 jag supercharged, my car will start with no problems and no dash warnings, but as soon as i set the car into reverse or drive or sports mode, car won't kick into any of the gears and a transmission fault appears on dash, could this be a cause of low oil or a bad sensor ? please help.
Old Mar 6, 2018 | 01:25 AM
JagV8's Avatar
Even more likely is that one or both of the small (8mm hex head) bolts that holds the shift cable to the trans side (under the car) has come loose / fallen out.
Old Mar 6, 2018 | 08:32 AM
gextreme's Avatar
thanks so much for the quick response, and i would definitely check it out today as soon as i get to my shop, so thankful to have found this page as i have come across to be rather rare to find info on my vehicle. thanks jagv8
XJsc-guy
Jun 14, 2015 03:49 PM
wotcham8
Nov 9, 2013 07:05 PM
Terry H
Aug 6, 2013 03:02 AM
Gatorbaiter10
30
Dec 17, 2012 04:21 PM
peruano4life
May 30, 2011 08:54 AM
