XF (X260) 2015 onwards
2013 XF Radio/backup cam/locks not working
Old Dec 10, 2020 | 02:09 PM
pharmer's Avatar
Default 2013 XF Radio/backup cam/locks not working
Hi all, A few weeks ago, I left the drivers window down and we had a rain storm overnight. Now, my radio is not working nor is my backup camera and door locks. I pulled the seat out and find that the Sirius module looks fairly corroded. Would that unit also be responsible for my door locks and backup camera not working? Please let me know your thoughts and what other modules, etc. I will need to check.
Thank you, Chris
Old Dec 14, 2020 | 09:19 PM
pharmer's Avatar
Wow - 117 views and no replies? Any advice would be sincerely appreciated!
Old Dec 15, 2020 | 06:48 AM
kkurulak's Avatar
Hi pharmer, you might get a better responds if you posted in the X250 section. What does your scan tell you? As the information points to possible water damage, it could be a multitude of different areas, from slight corrosion on a connection to a damaged module or component or even nothing related to moisture . The first thing would be to retrieve some codes so a trace can be started otherwise it will be all guess work anyway.
Old Dec 15, 2020 | 09:36 AM
pharmer's Avatar
Thanks for the feedback. Yes, I realized that I posted on the wrote forum and have resubmitted to the correct one.
Ric Gallaher
Sep 11, 2017 11:09 AM
maxgkm
May 6, 2017 05:01 AM
nostra
Jul 27, 2014 01:07 PM
Venture
Sep 21, 2012 04:33 AM
sdjdguy
Apr 20, 2012 07:52 PM
