XF (X260) 2015 onwards
2017 xf leaking under water pump
Old Aug 12, 2022 | 04:33 PM
Begjr2's Avatar
Default 2017 xf leaking under water pump
Hey gents,
I'm stuck when it comes to my 2017 XF. I recently had a coolant leak that i discovered was coming from my pump. After replacing my old pump with the new one, now im getting a constant flow coming from underneath the new pump under the left bottom side of the pump. I have cleaned and reseated the pump 100 times and for the love of God I can not figure out why is it still leaking. I have even made sure the gasket are contacting correctly. Need some help
thank you
Old Aug 12, 2022 | 05:38 PM
Fraser Mitchell's Avatar
Best if you post in the forum for your car
Old Aug 12, 2022 | 08:35 PM
Begjr2's Avatar
Isn't this the XF group?
Old Aug 12, 2022 | 10:12 PM
Lordchompybits's Avatar
It is! I had what seemed to be a leaking water pump turn out to be a cracked coolant pipe underneath the supercharger. Another theory is that you have bought a defective pump.
Old Aug 18, 2022 | 06:53 AM
Begjr2's Avatar
I looked at the super charger line and it looked good plus when I run new coolant in the tank it's flowing out behind the pump excessively. Any other suggestions?
thank you
F1Virginia
XF (X260)
Apr 12, 2022 04:08 PM
aquifer
Jul 21, 2021 11:42 PM
Doug
Oct 29, 2012 09:55 AM
sidescrollin
Mar 5, 2012 09:43 PM
bedford17
Aug 7, 2011 02:08 PM
