XF (X260) 2015 onwards
AJ126 timing chain replacement interval?
Old Oct 10, 2025 | 05:56 PM
elfer's Avatar
Default AJ126 timing chain replacement interval?
Hi great forum community,
for aj126 v6, how often timing chain needs to be changed/replaced? Some places claim 80 - 100 000km, some people claim 150- 200 000km, ?
Please advice also how much this job cost.
Old Oct 11, 2025 | 11:31 AM
clubairth1's Avatar
Community Influencer
Change them when needed. It's just too expensive to change parts until they are worn out.
The best thing you can do as an owner is to change the oil at 6K miles or so.
Old Oct 11, 2025 | 05:24 PM
Jay35's Avatar
The AJ126 V6 timing chain is designed to last the life of the engine. There is no set mileage for replacement.
It should easily last over 150,000 miles with proper maintenance. The most important thing is regular oil changes. Letting the oil get low is what causes the chains to wear and start rattling.
You only need to replace it if you hear a rattling noise on cold startup.
The job is very expensive. Expect a cost between $3,000 and $5,000 because the entire front of the engine must be taken apart.
Old Oct 11, 2025 | 06:04 PM
elfer's Avatar
Jag dealership told me 10.000$ for timing chain replacement.
also some people places claim timing chain needs to be replaced at some points at around 50 .000miles some places claim more?
Paul Jeeves
Feb 9, 2025 12:33 PM
JordanXJL
Mar 10, 2023 12:16 PM
asjdhsajhdfj
Jul 1, 2021 09:13 AM
Gom
Mar 13, 2018 09:59 PM
filoli1993
Dec 17, 2010 01:40 AM
