XF (X260) 2015 onwards
Ambient lighting
Old Oct 11, 2022 | 04:14 AM
Ian D's Avatar
Default Ambient lighting
Does anyone have ambient lighting upgrade option in their XF?
I'm trying to locate where all the LEDs are for this, there's a large one shown that is across the fascia (dashboard no.13 on image) but I can't see where it fits?
Maybe someone could take a picture of where this LED is located for me?
Also do ALL the lights turn red with dynamic mode or just a select few?
Old Oct 11, 2022 | 02:46 PM
Ian D's Avatar
Ok I’ve found that the lower strip across the dash is different as it houses the LED.
Can anyone let me know how dynamic mode looks with the ambient lighting? How the rear lights look in footwells as well?
Does the LED for the Jaguar logo change at all?
Old Oct 12, 2022 | 06:09 AM
Ian D's Avatar
I've bought the centre console harness, found some door panels on ebay that had the ambient lighting and just need a couple more parts.
Really interested in finding out though where the rear foot lights go and whether or not all lights go red with dynamic. As I'll have to solder in wiring for the bottom LED strip in the doors due to lack of harness.
Old Oct 12, 2022 | 09:24 PM
dennis black's Avatar
20 Year Member
my 2015 portfolio has it ,ill get some pics for you
Old Nov 10, 2022 | 05:15 PM
EliteZags's Avatar
off topic has anyone ever considered installing this illuminated badge to the grill? Its cheap enough to want to at least fit to see how it looks, just trying to figure out how straightforward the wiring would be to connect
Old Nov 11, 2022 | 04:16 PM
EliteZags's Avatar
I ordered one to try out for fun, TBD if I can actually get it wired correctly, here's the instruction seller gave:
I'd assume it should connect to one of the front LED headlight 15A fuses in the engine fuse box(XJ), anyone done this before can you just pull it out, wrap wire around prong, and stick back in? kinda skeptical it'll work
rtmyers1
Apr 19, 2022 08:53 PM
CryptoCowboy 01
Apr 20, 2019 07:26 PM
WhiteTardis
Jan 29, 2018 06:43 AM
New2Jag
Nov 1, 2013 09:24 AM
