XF (X260) 2015 onwards
Can anyone tell me what this is?
Old Jun 8, 2026 | 06:08 PM
sb53's Avatar
Default Can anyone tell me what this is?
Does anyone know what this cover is called and what it covers on the 2016 3.0 Supercharged? Here is a photo with the cover circled in yellow. I was wondering if there is a gasket as I have a little tiny drip of oil coming from the bottom of this cover and would like to stop the leak. Thank you in advance!!
Old Jun 8, 2026 | 06:16 PM
RoverJoe's Avatar
Community Influencer
That's your vacuum pump. Don't remove that cover, it's not serviceable. It is held on by 2 bolts and driven off the lower cam that runs the fuel pumps. If the engine is full of oil, it's below the level and will leak out 2-3 quarts when removed. The pump seals to the front of the engine with a seal that fails with age. That's most likely your leak, not the cover of the pump itself.
Old Jun 8, 2026 | 06:19 PM
sb53's Avatar
Yes, it does have a vacuum line attached to it. It was only one drop of oil that leaked from it so I wanted to find out what I was looking at to replace or repair if it becomes more concerning. Thank you for your quick answer!! I will keep an eye on it!
Old Jun 8, 2026 | 06:32 PM
sb53's Avatar
Could you confirm this is the seal for the pump? If I replace it, do I need to do anything else out of the ordinary other than remove the two bolts and pull it out and replace the seal? Thank you in advance!!
https://www.autohausaz.com/pn/EU-C2D3771
Old Jun 8, 2026 | 06:38 PM
RoverJoe's Avatar
That looks correct, and no there's nothing else to it, just the 2 bolts, and drain off some oil first so you don't take a bath in engine oil when you remove it. If you do it during an oil change, it should only at 10 min to the job.
Old Jun 8, 2026 | 06:51 PM
sb53's Avatar
Thank you so much! I found a video on it also just now that shows how to replace all the gaskets internally also if anyone is interested. The actual removal of the pump begins at the 1:15 mark of the video. Here it is. Again, you've been a great help and put my mind at ease. Thanks again!
sb53
Yesterday 09:44 AM
pcock111
May 6, 2026 01:23 AM
Xjgrey
Dec 12, 2021 06:04 PM
EmmanuelTam
May 21, 2020 09:18 AM
rayzsurfer
Feb 26, 2020 09:42 PM
