XF (X260) 2015 onwards
Cold Start issues
Old Feb 28, 2022 | 11:45 AM
2011_XF_5.0's Avatar
Default Cold Start issues
I’ve got a cold start issue. Like a fuel starvation on cold starts, throwing restricted performance and low/high fuel rail pressure bank 1codes. 5.0 gasoline engine. 2011 model. It only does this on cold starts. If I switch off the engine off it will start right back up with no issues, runs and drives fine. I’ve replaced both high pressure pumps and the filter/flange in the tank. Is there another fuel filter somewhere or maybe a check valve?
Old Mar 1, 2022 | 04:23 AM
nicktee55's Avatar
Hi, you're in the X260 forum for post 2015 models. There's a forum on this site for the X250 model where others may be able to help you.
retroren
Dec 21, 2021 08:14 AM
pyro
Jan 5, 2020 06:47 PM
Mike Sarli
Feb 16, 2016 11:53 AM
Forcedair1
Apr 22, 2015 11:36 PM
chater210
May 16, 2014 08:29 AM
