XF (X260) 2015 onwards
Do i scrap or do i replace engine
Old Mar 31, 2025 | 04:33 AM
CHarro's Avatar
Default Do i scrap or do i replace engine
Qu. Replace engine or scrap and take the loss - without the convoluted back story i find myself in a zero sum game with my 2015 Jag XF 2.0L Diesel ingenium. After some diagnostics, inspections and I have been told by a Independent Jag specialist the following. "did some extra tests- we tried with some easy start and it attempts to fire but it wont have it so i'm afraid its down to lack of compression- I suspect piston and liner wear" recommending engine change instead of repair. A previous diagnostics also reported NOX, EGR and engine mountings issues as well.
Value / cost is a factor. Any advice , your experiences and knowledge would be very much appreciated. I'm located Aylesbury, Buckinghamshire and the car is broke in a nearby garage who cannot be part of any solution. Many thanks
Old Mar 31, 2025 | 04:48 AM
CHarro's Avatar
By the way its my first Jag, first post of the forum and i'm in no way a wannabee mechanic , i leave that to the more abled than me
Old Mar 31, 2025 | 09:20 AM
nicktee55's Avatar
A reconditioned like-for-like exchange engine will cost you around £4000-4500, there are plenty around.
Then there's the labour to consider.
It may then be that your car is worth less than your outlay. That's fine if you intend hanging on to it for a good while - otherwise if you can, break it for parts, you'll get more than the scrap value.
Rack Jussell
Mar 31, 2025 04:40 AM
qldscottie
XF (X260)
Nov 2, 2024 03:33 AM
FourLitres
Jul 23, 2024 05:56 PM
Billjg75
F-Pace (X761) / C-X17
Jun 18, 2024 08:41 PM
pullingmyhairout
General Tech Help
Mar 21, 2024 07:38 PM
