XF (X260) 2015 onwards
Driver Side View Mirror intermittent operation
Old Nov 12, 2019 | 05:39 PM
LeeC's Avatar
Default Driver Side View Mirror intermittent operation
After having my Jag for about a year the driver side view mirror stopped fanning out when the car was turned on. I called service and was told that the issue occurs when the mirror gets bumped, possibly by someone walking by. They told me that to get it to work that I was to drive forward and hit the control buttons again. This did fix it.
However, now it happens more often then not. It’s intermittent, but instead of happening once a month, it happens several times a week. Has anyone had this same issue?
Old Nov 13, 2019 | 05:01 AM
Welcome to the forums LeeC,
It would help to know which Model and Year this is.
Old Nov 13, 2019 | 02:14 PM
LeeC's Avatar
It’s a 2017 XF
Old Nov 13, 2019 | 02:44 PM
Originally Posted by LeeC
It’s a 2017 XF
Thanks for the clarification.
I've moved your question from General Tech Help to X260 forum for advice from members with the same model.
Old Nov 13, 2019 | 02:57 PM
..... I called service and was told that the issue occurs when the mirror gets bumped, possibly by someone walking by. They told me that to get it to work that I was to drive forward and hit the control buttons again. .....
Often when the door mirror is bumped, the housing is pushed off the motor drive peg.
You can check for this by trying to rotate the mirror body by hand when it's in the (unfolded) driving position. It should be firm but if you can move it, it's not seated properly on the drive peg. When this happens you can usually feel it click back into place.
Paul Nattis
F-Pace (X761) / C-X17
Jan 5, 2024 10:04 AM
horganrich48
Jul 25, 2019 11:13 AM
brianp
Oct 8, 2014 04:54 AM
Akingmitch
May 14, 2014 05:22 PM
