Engine Oil Level Critically Low
No , i didnt even bothered , it s probably an electric issue , or maybe it needs a software reset of the ecu i dont know ,lucky for me i just don t drive so much i just made 7000 km in 2 years
Hi all,
I have a peculiar problem with my Jag (X260) XF. Every now and then (at random times) I recieve an error message "Engine Oil Level Critically Low" on the dash. I checked it with one of the dealers in Bristol but they couldn't find any problems when they ran a diagnostic. The engineer suggested to change oil pressure switch to see if that could resolve the issue. So I went ahead and requested to change it but with no joy. I then took to another dealership and the engineer suggested it could be a piston cooling jet but not sure about it (We went into lockdown so I couldn't get that done). Nonetheless, I took the car for service (major 105,000 miles service) to the dealership and they ran eVHS service but the system did not find any faults. The car shows everything is running fine with no historic issues from the system.
I am wondering, does anyone here have had same experience and if yes then what did you do to fix/correct it?
The error pops up at random, there is no fix time or method of running that would trigger it. Can you also recommend where I can buy JLR diagnostic kit so that I can run it myself?
Many thanks in advance
Kind regards
Jay
Kind regards
Jay
Jaguar XF X260, even with correct oil levels, often point to a malfunctioning oil level sensor, a faulty oil pressure sensor, or a, sometimes, failing piston cooling solenoid. These intermittent warnings frequently appear while idling or driving at high speeds. More likely level sensor
Since it does starve vital engine bearings of oil it does need fixing sooner rather than later
