XF (X260) 2015 onwards
Front control arm bushings cracked - cost to replace?
Old Apr 19, 2022 | 04:04 PM
kairos's Avatar
Default Front control arm bushings cracked - cost to replace?
Hey guys,
I have a 2017 Jaguar XF S (gas)
So apparently my front control arm bushings are cracked/starting to wear. The dealer told me that they can't replace the bushings without replacing the entire control arm. is this true?
They're wanting to replace both the front control arms plus the bushings to the tune of ~$1200.
Wondering if this is one of those things I just have to bite the bullet on and get done by the dealer, or if I should go take it to a Jaguar specialist shop instead and get a quote from them instead.
any help is greatly appreciated!!
Old Apr 19, 2022 | 09:55 PM
2018XF25T's Avatar
The dealer got lazy and just want to install the entire control arm assembly. It is costly but easy for them to install. I am not into throwing things that are still usable.
A control arm bushing replacement isn't hard to do. A qualified mechanic can do this as long as he/she has the proper specialized tools. It is a good idea to replace both bushings. You may need a wheel alignment after the job is done.
Old Apr 20, 2022 | 04:04 PM
Fraser Mitchell's Avatar
Much depends on the balance between additional labour charges for swapping out the bushes, against just swapping the arms out with new ones that cost a lot more than just bushes. Either job involves taking the arm off and putting one back, plus realignment. Jaguar specialists tend to invest in the tools needed to swap control arm bushes, but jobbing shops won't as they won't see many Jaguars in their shop.
Old Apr 21, 2022 | 09:43 AM
Rummy636's Avatar
From what i remember, Jaguar doesnt offer a bushing separate from arm. That is why whole arm is recommended.
Old Apr 21, 2022 | 04:00 PM
Not true. The big trunnion bushes are freely available, and I had mine replaced on my 2003 XJ6 some time in 2014. Some bushes on other suspension components are not sold separately, but usually the aftermarket supplies them.
Old Apr 21, 2022 | 06:33 PM
Rummy636's Avatar
…and that is the key. You’re 03 XJ6 does but the X260 does not. The front lower control arm bush is not available separately at the dealer. Aftermarket I would assume so. If you have access to EPC, it shows arm only.
Old Apr 21, 2022 | 07:03 PM
mleskovar's Avatar
Originally Posted by kairos
Hey guys,
Never hurts to get an indy quote. Online parts stores don't list the bushings separately. I'm curious about the symptoms you had that lead to diagnosing the bushings being bad. Upper or lower control arms?
Old Apr 22, 2022 | 10:53 PM
F1Virginia's Avatar
Hey guys,
1 and Done...?
Old Apr 26, 2022 | 04:53 PM
harryf's Avatar
They should be able to replace the bushings. It's not an easy job, thus they will charge you about $1000 for the labor. I think I paid $45 for the bushings.
Old May 23, 2022 | 11:02 AM
Sabrinaservicewriter's Avatar
Hey Kairos!
I completely understand why you would want to know if it's serviceable separate from the whole arm. On the newer XJ's they have finally created the front lower control arm bushing which is part number C2D4723. Unfortunately we have not been able to locate that bushing for the XF. The two part numbers I was able to locate for control arm bushings are T2H24313 that's the smaller inner bushing and C2D6787 is the smaller lateral control arm bushing. I do hope Jaguar or an aftermarket company makes the bushing separate because the arms really are expensive, even the aftermarket ones. Not exactly what you were looking for but maybe this will help you in the future or someone else who is wondering a similar question.
Old May 23, 2022 | 06:28 PM
pk4144's Avatar
I will tell you what I know from an XKR:
First, the XKR forum is filled with incredibly knowledgeable folks who who can deep dive pretty much anything having to do with our cars. More than a few of the members have done bushing replacements themselves (to answer another question on this thread, yes, theyre aftermarket bushings), but for most this is not a DIY job. This issue has been covered there, I've had this work done on my XKR at a dealership, and here's the upshot:
- on the XK/XKR at least, the dealerships only stock the control arm assembly, which contains the bushings, so the repair is to replace the entire assembly. (And I will tell you that the price you were quoted for two is much less than the same repair/replace on an XKR)
- I'd also point out that those bushings are pressed into the control arms, and removal/replacement requires the right tools and some skill. As a dealer's Jag shop labor rate is about $180/hr (and up), it's not clear to me just how much money you'd save by going the replacement route even if the dealer were to agree to do it.
- these bushings are a known, ongoing issue on these cars, so much so that they're one of the things specifically NOT covered on the CPO extension of the warranty. So, long run, it's just something for you to plan for.
Finally, since you're out of warranty: this may be the perfect time to form a relationship with a good independent Jag mechanic. Shop around, ask for referrals, make a few calls and ask specifically whether they can replace control arm bushings or if they replace the whole assembly, and what's their price, etc.
You will find, on forums like these, that there's a lot of "I'm too smart to trust a dealer or a mechanic" kind of talk-- but as someone who worked in the bays at a Pontiac dealership, I can tell you that for the most part this is not true. (There's a guy on the XKR forum who thinks calling dealerships ***********s is oh so clever...) Yes, a good indie tends to be cheaper simply due to lower overhead (no fancy waiting rooms! No free Nespresso!), but don't call a dealer's service department with the assumption that you're going to get taken advantage of. Not always the case.
Good luck!
Old May 23, 2022 | 06:32 PM
pk4144's Avatar
Apparently (and unlike the X150 forum), this forum censors the made-up word " s t e a l e r s h i p s . "
95Leaper
XJ40 ( XJ81 )
Mar 10, 2017 08:07 PM
Gus
Nov 26, 2012 03:11 PM
SirJag
May 19, 2011 08:37 AM
eastsidejp
16
Dec 22, 2010 07:17 PM
