XF (X260) 2015 onwards
Image Processing Module "B" A failure occurred - Error code A01 Communications failur
Old Jun 28, 2024 | 04:00 AM
Rbrites's Avatar
Default Image Processing Module "B" A failure occurred - Error code A01 Communications failur
Hi,
Iam getting this error msg on sdd
And now i dont have reverse camera and allways a amber light on dash
The error on sdd is this
A failure occurred - Error code A01 Communications failure
for a jaguar xf x260 2016 model.
Can anyone point me in the correcr way
i have tried to update the module but fails mid way.
Old Jun 29, 2024 | 02:28 PM
Rbrites's Avatar
Originally Posted by Rbrites
Hi,
Iam getting this error msg on sdd, after replacing car battery.
Here is the image, after searching the internet I took the risk and ticked the green tick. For the image peocessing module. After 30mins of silence, car woke up and now I finally have the 360 cameras working again.
All ok, after a couple of days got it working
Old Nov 1, 2025 | 05:00 AM
scg661's Avatar
Realise this is over a year old, but how did you solve the error? Same car and im trying to update the IPMA but getting the same error you had.
This is happening after the screen you show above and seems to be an issue communicating to the module.
Thanks!
Old Feb 9, 2026 | 05:06 AM
Pawkc's Avatar
Thanks!
did you solve it?
Old Feb 10, 2026 | 03:34 AM
scg661's Avatar
Originally Posted by Pawkc
did you solve it?
​​​​​​​I bought a new A module, but before swapping it I tried mine again and it just worked...did nothing different and makes no sense. I cant remeber now if it could have been due to the JLR servers being down and then being back online. Had same issue with parking module. It didnt ever work and I bought a used one for a few quid and replaced and everything worked again.
Necromant1k
Nov 2, 2025 11:28 AM
Blubbers
Dec 21, 2023 10:30 PM
KKostas
Sep 18, 2022 11:55 AM
harryf
May 17, 2018 02:54 PM
RCSnyder
Apr 28, 2017 04:00 PM
