CONFIG F in and XJR?
Old Jan 21, 2015 | 02:36 PM
RCSnyder's Avatar
Default CONFIG F in and XJR?
I've searched and found references to several other Config letters, but no F.
Got this today after running diagnostics on my car. Hmmm.
Seems to run fine, but for the persistent Check Engine lamp.
Please advise.
Thanks in advance.
Old Jan 21, 2015 | 02:57 PM
Cambo's Avatar
The CONFIG message means that a module has lost its programming and needs to be reflashed. (you saw this thread https://www.jaguarforums.com/forum/x...solved-102871/ ?)
Not sure which module F is referring to though...
Old Jan 21, 2015 | 03:21 PM
RCSnyder's Avatar
I'd scanned that thread and was hoping a reprogramming might not be required. Oh well.
Now to play with the JLR/SDD to figure out why reprogramming is not an option available to me at the moment. Seems it thinks it's out of date and needs an update.
Thanks again.
Old Jan 21, 2015 | 03:39 PM
Blairware's Avatar
Unless it actually IS an "E" and the display is out on the bottom edge!
Seriously though - not sure how he is going to determine what module needs reflash.
Old Jan 24, 2015 | 06:05 PM
RCSnyder's Avatar
Not sure what it was but cleared the codes and it went away. Oh well.
Old Jan 24, 2015 | 07:26 PM
Sochi2014's Avatar
Got some GONFIG X message one day. Just reconnected the battery and all gone. No wait or any African instrument dancing with.
Old Apr 28, 2017 | 04:00 PM
englishdan's Avatar
Default Solved. GECM lost its programming
Config F actually refers to the Front Electrical Control Module but it is programmed and configured as part of the General Electrical Control Module. This can be done with SDD/JLR software from the diagnosis section AFTER you have run a full vehicle scan. Select program existing general module, it'll take about 5 nail biting minutes and then it'll ask if you'd like to program your module, say yes, select automatic and bite your nails some more. All done. My car had quit any window, sunroof, lighting or anything until I did this.
I figure the module may be on it's way out but at least the car is operational until I get one from eBay..
MrWhite
19
Jun 14, 2022 07:49 PM
MrWhite
Oct 1, 2015 01:43 AM
JAMES1944
Sep 29, 2015 11:58 AM
N3yyz_XJR
Sep 27, 2015 11:26 AM
moff1959
Sep 26, 2015 05:35 PM
