XF (X260) 2015 onwards
Key Fob
Old Mar 16, 2023 | 09:49 PM
hcardle's Avatar
Default Key Fob
I posted this in south Australia section.
If you are having problems with the key just check the circuit board. It's quite easy to remove and put back
Mine had all this contamination. Easily cleaned with IPA
Old Mar 20, 2023 | 10:17 AM
txjagwag's Avatar
Looks like the rubber cover came loose and moisture got in. Never good for PCBs
Old Mar 21, 2023 | 11:11 PM
hcardle's Avatar
Those Jaguar rubber covers are uesless. I bought a couple of these https://www.aliexpress.com/item/1005...37731802T7XjQm
work very well.
Old Mar 23, 2023 | 03:41 PM
txjagwag's Avatar
Are those add on covers or replacement for the bonded rubber? The bonded rubber it the problem I see. I have a key (was the PO primary key) that the rubber has become unglued from the key body and I can see directly onto the PCB. This would appear to be the cause of the the OP's problem.
Old Mar 27, 2023 | 08:40 PM
hcardle's Avatar
Thiose add on covers go over the entire fob including the rubber. These are rubbish but the covers are excellent.
Old Mar 27, 2023 | 08:49 PM
hcardle's Avatar
The video in the advert shows how to assemble it. You do need to take off the little split ring. See pic.
Tracee
Jun 3, 2022 05:59 PM
RGPV6S
Apr 17, 2022 05:00 PM
dougdean
Sep 23, 2021 07:57 AM
Zahmed1094
Dec 24, 2018 10:58 AM
Carthage4404
Mar 19, 2013 03:02 PM
