XF (X260) 2015 onwards
Lug Nuts
Old Jan 29, 2023 | 03:45 AM
OzXFR's Avatar
Well when have you EVER seen a tire guy NOT use an impact?
My tyre shop does the right thing - does the nuts up snug but not over tight with an impact on the weakest setting then drops the car to the ground and torques them up to spec using a manual torque wrench.
So yes they all use an impact wrench but some still do it right.
Old Jan 29, 2023 | 09:14 AM
kansanbrit's Avatar
OK, should have said impacts set on high. I use one myself to snug the nuts up, then torque them. But I grew up in the racing world so don't let everyday tire guys near my cars 😁
Old Feb 3, 2023 | 07:08 AM
chrisjp's Avatar
The other problem with clad lug nuts is that, if the car is used on salt-laden winter roads, the nut inside the cladding can corrode because it is just mild steel. The rust that forms expands and distorts the cladding outwards so that the normal 19mm or 3/4" socket won't fit. Then you're reduced to hammering it on or trying to use a larger socket which will probably slip.
Old Jul 27, 2024 | 10:06 PM
yeet's Avatar
Originally Posted by NewLester de Rocin
That must be painful. Yes, many of the lugs do have the decorative cap. I have yet to learn if the actual OEM lugs have the caps, OR if just the lugs that mechanics along the way working on your car REPLACED on your wheels whenever they damage your original lug with their impact power-wrenches.
Early in my ownership, I elected to buy TWO things for myself to keep. One, a bag of TRUE chrome-finish lug nuts (you can get a bag of 16 or so on Amazon-UK). A reckon, as long as I am the one putting them on, they won't be chewed up so fast.
The second thing was a SPOKE-style lug wrench, with the 17 thru 20 lug sizes on it, and the plastic collar on the ends to keep from scarring your wheels. I chose a chrome-molybdenum metal wrench because it's so light compared with the old grandparents' wrench. Check out the wrench from Motamec.
Keep these two items in your home, not just for this, but for most of your future cars. Damn those mechanics, with clumsy hands like glazed ham shanks.
typically the oem ones are capped these days, youre better off tossing them in the trash and getting lugs that you can see through both ends like you dan on these when they lose the cap. doesnt matter how careful you are, that cap will eventually break loose, and its likely to round off the lug underneath when it does
J5hort
Nov 12, 2021 08:25 AM
staggerwing17
31
Nov 8, 2021 08:06 AM
MWave
16
May 18, 2019 05:37 PM
giandanielxk8
Apr 3, 2018 10:27 AM
Noxparadise
Dec 1, 2012 10:16 PM
