XF (X260) 2015 onwards
OBD II
Old Oct 17, 2023 | 09:44 AM
mleskovar's Avatar
Originally Posted by hcardle
Battery sits at about 12.7v when car is off. 14.85 when on and charging. Both DVM under hood and live data on scanner.
How many miles have you put on it since battery replacement? Voltage is good both static and charging so you should be good to go. I don't know how this BMS system works if the "low battery voltage" warning has been tripped and if it needs to be reset or it should just reset on its' own after the voltage is brought up. Does the SS work now?
Old Oct 17, 2023 | 09:45 PM
hcardle's Avatar
I visited my expert yesterday and he used his high spec Autel scanner to interrogate the BMS and registered a new battery. Drove home, 40 minutes and had everything working perfectly.
Old Oct 18, 2023 | 04:50 AM
dangoesfast's Avatar
Thanks for updating with the result, I was following along as I'm about a month away from doing a battery myself.
Do you happen to know the model of scanner your guy used? In the market for one myself for work and would love one that can do all the Jag stuff.
Old Oct 18, 2023 | 06:33 AM
hcardle's Avatar
Not sure but it's about $10k with annual $1700 for all updates.
Looks like maxisys. 909 or 919.
Ultra?
Old Oct 18, 2023 | 06:47 AM
Ultra?
Thanks, I'll look into it a bit more. We need one at work but maybe don't need it quite that badly 😂 cheers
Old Oct 18, 2023 | 09:23 AM
mleskovar's Avatar
Great! I'm curious ..... did the SS work even though it showed the low battery condition message after the new battery?
Old Oct 18, 2023 | 06:08 PM
hcardle's Avatar
No. SS only started working when new battery was registered in BMS.
It might just be imagination but car feels better, smoother. I did save some live data so might have another look to see if there is any difference.
Old Oct 18, 2023 | 07:05 PM
  #28
mleskovar's Avatar
...It might just be imagination but car feels better, smoother. I did save some live data so might have another look to see if there is any difference.
Cars always feel better when everything is working the way it should after repairs
Old Oct 20, 2023 | 07:15 PM
hcardle's Avatar
I topped up the windscreen washer today and I swear it has more power.
Old Oct 23, 2023 | 10:13 AM
  #30
mleskovar's Avatar
I read on another forum that the battery warning message will "eventually" go away on its' own if the battery is sufficiently charged and the alternator is working properly.
Old Nov 4, 2023 | 11:43 AM
  #31
NickJagXF's Avatar
As I am getting ready to do a battery replacement on my 2011 XF, I have been diving heavily into the subject as of late, and between studying several jag forums, there appears to be a inconsistent set of results when people replace their batteries but don't register it. The results range the entire spectrum from everything worked as intended, to I bricked my car and it had to be towed.
More often than not though, most people have reported that it's far better / safer to register the battery, than to take a chance and "wait" for the BMS to sort it out on it's own, as that can take upwards of 6 months or it some cases it may never sort itself out.
Interestingly, from an excerpt in a Jag service manual, if you replace the BMS sensor on the battery cable at the same time with a new one, the new one will auto-calibrate for you.. makes you wonder why it doesn't do that all the time?
Assuming that most people don't replace this sensor, (I'm not planning on it), I'm going to go the safe route and register the battery to the car when I change it. I bought an iCarsoft v2 based on recommendations from other Jag owners, and hopefully that will communicate properly with my XF.
Also fully expecting to have to do all the window / EPB resets after changing the battery.
Should be doing the battery change this upcoming week, I'll let you know.
Old Nov 4, 2023 | 12:30 PM
  #32
mleskovar's Avatar
Wrong forum, you want X250. The X250 has two batteries, a separate one for the Stop/Start, and the BMS probably (?) works differently.
Old Nov 4, 2023 | 12:50 PM
  #33
NickJagXF's Avatar
Whoops, my bad. My apologies. I'm new here
Old Aug 3, 2025 | 04:31 AM
  #34
hcardle's Avatar
Its a MultiCAN Network.
File Type: pdf
erndog
XF (X260)
Aug 26, 2021 06:50 AM
2018XF25T
XF (X260)
Jun 22, 2021 09:48 AM
multistrada74
Mar 30, 2020 09:57 AM
christopher97
Mar 10, 2020 06:32 PM
AdzBo
May 1, 2012 02:57 PM
