XF (X260) 2015 onwards
OBD2 question
Old Aug 22, 2021 | 09:54 AM
erndog's Avatar
Default OBD2 question
I am the new owner of a 2017 XF. I have never owned a Jaguar before, so I am trying to get used to its nuances.
I have a very good OBD2 code reader, but I see that the receptacle under the dash doesn't match any of the adapters I have. Typically, these are a tapered rectangle, but this car has a squared-off rectangle with a tab at either end. The car is British made vs. made in USA, so maybe England uses different connectors?
Could someone enlighten me please?
I was wrong. It has the standard plug-in. I would delete this post if I knew how.
Old Aug 25, 2021 | 08:09 PM
Kodiak's Avatar
You must be looking in the wrong place. The OBD2 connector is above the hood release (maybe a little to the right) and has the standard trapezoidal shape with a notch on the short side. Crawl into the driver's footwell with a flashlight and look up under the dash and you'll see it.
Old Aug 26, 2021 | 06:50 AM
erndog's Avatar
Thank you. I found it, but can't delete the post.
mynameismonkey
XF (X260)
Jan 27, 2020 08:02 PM
Philkitter
Sep 19, 2016 06:37 AM
Brooke
XF (X260)
Apr 13, 2016 11:12 AM
jagtoes
Mar 18, 2016 06:24 AM
JappoJappo
Sep 24, 2009 09:29 PM
