XF (X260) 2015 onwards
P008B
Old Nov 29, 2022 | 11:56 AM
Ashawnti1's Avatar
Default P008B
I'm new here. I saw where the other member said he saw the code but the common symptom with the threads I saw was smoke. I'm getting the code it's not smoking though. It did die on me Sat for a couple days and started back up. The code is saying high fuel pressure and suggesting a fuel pump replacement. Is there a separate fuel pressure sensor or regulator, and if I do replace the whole pump which should I replace or both
Old Nov 30, 2022 | 04:38 AM
Welcome to the forums Ashawnti1,
No Model Year, engine type or location so we have no idea about the vehicle other than it is probably a current XF.
What decided you to check for DTC's and did you use compatible (dealer level) diagnostics capable of reading extended Pxxxx-yy codes? The extended code indicates whether it is driver module, pressure sensor or pump:
However, the first step is to eliminate battery (low charge/failing) and harness faults before considering component replacment.
Modern Jaguars usually show a list of codes simply as a result of sensors sometimes recording out-of-range values and therefore not all are indicative of a fault.
dogsoup
May 21, 2022 12:20 AM
Mongoose
Apr 13, 2021 06:40 PM
wrischan
Mar 25, 2021 07:15 PM
kolbe
Sep 9, 2020 04:15 AM
62sunbeam
Oct 6, 2013 10:08 PM
