XF (X260) 2015 onwards
Rear windows and moon roof not opening
Old Oct 27, 2024 | 06:01 PM
envincibal's Avatar
Default Rear windows and moon roof not opening
I'm hoping someone can give me some insight. 2016 Jaguar XF
Earlier today I tried to roll down the back windows (both sides) and the window click (moved a fraction of a fraction) and then stopped. Hit the switch to roll it up and again the same click and slight movement (fully closed). I tried this multiple times on both back windows and always met with the same result.
The moon roof responded in the same way, kinda. The roof would rise and open a crack, but would not fully retract for an open roof.
Thankfully, all windows closed. No issue with the front windows.
I had the battery replaced by the dealer back in May, and being in FL, I never have the windows down or the roof open until the weather finally cools off.
Any ideas as to what is happening and what the fix could be?
TIA
Old Nov 2, 2024 | 03:57 AM
2018XF25T's Avatar
Most common cause is dirt on the tracks. I hope it's not the motorized mechanism. I think I read in the owner's manual of the reset procedure sun/moon roof. I can't remember, it's in either my Jaguar's or Land Rover's owner's manual
Old Nov 20, 2024 | 11:34 AM
jokino's Avatar
The clicking sound you hear could indicate a problem with the window motor or opening mechanism. The motor may be stuck or damaged.
Old Nov 22, 2024 | 04:03 AM
2018XF25T's Avatar
In addition to my earlier post, try spraying the tracks with WD-40
Steve Bond
Apr 28, 2017 01:12 PM
Steve Bond
Apr 28, 2017 11:57 AM
Evl5
Apr 2, 2015 11:33 AM
abela
Mar 21, 2012 02:45 PM
abela
Feb 15, 2012 08:47 PM
