XF (X260) 2015 onwards
Rebuilding 306PS motor
Old Apr 6, 2022 | 10:59 AM
DutchKiwi's Avatar
Default Rebuilding 306PS motor
I have a problem with the alignment of the of the furl cam shaft and the crank shaft. If the markings on the chain are a lined with the markings on the cogs as per the workshop manual, the fuel pump cam alignment is out by one tooth?
Looks like she got a little hot?
I see that when my alignment timing tool that locks the motor at TDC is inserted, cylinder one is not at TDC? But the crank shaft key way is at 6:00 o clock and the mark on the crank is pointing down (6:00)
Old Apr 19, 2022 | 07:54 AM
DutchKiwi's Avatar
Update to timing problem.
Old Apr 26, 2022 | 02:23 PM
DutchKiwi's Avatar
Still can't get it aligned?
Old Apr 29, 2022 | 01:12 PM
DutchKiwi's Avatar
Update
Old Apr 29, 2022 | 01:37 PM
DutchKiwi's Avatar
I see that the flywheel locking tool (JLR 303-1303) locks the crankshaft in the "timed position" as per the Jaguar workshop manual. This is not TDC.
Old May 5, 2022 | 12:04 PM
DutchKiwi's Avatar
jcuba53
Jun 7, 2015 09:34 PM
michaem101
Jun 5, 2010 10:43 PM
Jagbuff
Oct 9, 2009 09:32 AM
Rlover
Apr 12, 2009 04:21 PM
Brake buster
Mar 31, 2008 03:47 PM
