XF (X260) 2015 onwards
Require PIN To Start Car (Is It Available?)
Old Oct 15, 2019 | 04:49 AM
DMR123's Avatar
Default Require PIN To Start Car (Is It Available?)
Hi,
I’ve just purchased a Jaguar XF R-Sport, I know there’s a “valet” feature which restricts access to certain things, but is there a feature which can be enabled that requires a PIN code to start the vehicle?
Old Oct 15, 2019 | 05:16 AM
Welcome to the forums Dan,
I've moved your question from General Tech Help to X260 forum. Members here with the same model will be able to help.
Old Oct 15, 2019 | 06:44 PM
CarsonCitySmith's Avatar
There is some kind of App for your phone, In Connect I think is the term. I just bought an XF and I was reading the Owner's Manual. I have not tried to get the App but I think it requires a PIN to start your car remotely. Otherwise you just get in the car with the key fob in your pocket, press the brake pedal and push the start button. Or don't press the brake pedal and the ignition will turn on but not start the engine.
Read the Owner's Manual a couple times. Available on line if you don't have a hard copy.
P.
Old Oct 15, 2019 | 07:03 PM
XFJoe's Avatar
Originally Posted by DMR123
Hi,
I think the answer is no, but what would be the purpose? Are you wanting someone without a key to start the car? As was mentioned, you can start it from the Remote app, but you can't drive it unless a smart key is also present.
Enrico Spoletini
XF (X260)
Mar 21, 2019 10:58 AM
2015Coupe
Nov 8, 2017 01:05 PM
kimoto
Apr 13, 2014 08:43 AM
Robert Page
Mar 6, 2013 07:01 AM
