XF (X260) 2015 onwards
SDD program fail
Old Aug 17, 2022 | 04:16 PM
Toffeetv77's Avatar
Default SDD program fail
I attempted to do some programming on my xf but it failed now the car won’t start and the keys are not Recognised. The DTC is B1009-62 Ignition authorisation. Has anyone had this before and how did you fix it.
Old Aug 18, 2022 | 10:19 AM
Aarcuda's Avatar
Get a good battery charger and try to rematch the keys to the car. You need to have two keys to program them.
Old Aug 18, 2022 | 02:30 PM
Toffeetv77's Avatar
Thanks its in the dealership now having a new kvm and two new keys. Do you know if they would need to reprogram the IPC and BCM thanks
Old Aug 18, 2022 | 03:26 PM
MoJo88's Avatar
Sounds like it didn't need any of that. A quick remote session with myself and you would've been up & running.
Old Aug 18, 2022 | 04:57 PM
Toffeetv77's Avatar
Well they have said that the new kvm might not work and they would have to get a new central junction box and rear junction box. Which im thinking they will say just to get money out of me. So what would you do then if the kvm doesn’t work
Old Aug 19, 2022 | 09:05 AM
clubairth1's Avatar
Community Influencer
Hard to say but I was in that exact position with an earlier 2006 XJ. I did what was posted above. I tried to add some keys and only had one key. This means all keys must be erased before adding any back. Something happened during the programming (Most likely an error of some kind on my part I am sure!) and I could not complete the task leaving me with a car that the keys would turn in the ignition but nothing would happen electrically.
Started all over from scratch and went thru the entire procedure again and was successful. But I was sweating the whole time! I have read from Cambo that it's almost impossible to really brick a module and/or car. If you know what your doing you can wake up and reprogram your modules. I am not at that level...yet.
Your at their mercy now unless you are willing to take the car back and battle SDD again? Did you have the problems or did a shop you hired have problems with SDD?
Any more information on exactly what happened in the SDD session?
Maybe someone here could help?
Old Aug 19, 2022 | 10:30 AM
Toffeetv77's Avatar
Yes it was me i forgot to put my battery charger on and the battery power dropped half way through the program. So had the DTC B1009-62 Ignition authorisation. No response from the car with the keys. So disconnected the battery thinking it would reset but it didn’t. Now the car is in the dealership but they want to just replace things,
Old Aug 19, 2022 | 12:47 PM
Aarcuda's Avatar
Lol. When i first started playing with SDD I started the program to update the module and I got to the portion where it said it would now rematch the keys and I ignored the part about needing two keys and found out the hard way it really meant it. What I ended up doing was taking another key fob that didn’t go to the car (went to my parts car) and just swapped the key portion onto the fob for the second car to get it to finish. And then went and got the other key cut so I wouldn’t run into that problem again
Old Aug 19, 2022 | 01:11 PM
Toffeetv77's Avatar
Well some good news i have my car back and its working but with only one key working.
Old Aug 19, 2022 | 02:23 PM
clubairth1's Avatar
OK great! What did they find?
Don't delay in getting a second key either.
Old Aug 19, 2022 | 03:37 PM
Toffeetv77's Avatar
Yes need to get that sorted. They didn’t say what they done. Thanks anyway
nebelfuerst
General Tech Help
Jul 29, 2025 05:28 PM
Joel Brown
46
May 9, 2021 09:47 AM
gimag70
General Tech Help
22
Mar 4, 2021 10:11 AM
sayitaintso
Jan 29, 2018 07:04 PM
