XF (X260) 2015 onwards
Second Jag is a SPORTBRAKE!
Old Oct 10, 2021 | 09:19 PM
pk4144's Avatar
Default Second Jag is a SPORTBRAKE!
I saw one, loved it.... did some research and, after some haggling, now am the proud owner of a 2018 Sportbrake.
What's interesting is the little Jag things that are the same as (or different than) the XKR. To offer the most baffling example, both engines lack a dipstick, but-- in the xkr, its a lot easier to access the electronic readout.
Anyway, three quick questions though I'm sure I'll have more:
- it's nuts how much those rear seat headrests limit the rearview visibility. I have figured out how to fold them down, but is it possible to remove them entirely?
- reading through the manual, I see that the car has a luggage cover (?). There is not one in my car. Was this standard on these cars, or is this an option?
- has anyone replaced the wood insert trim pieces? I think the dark grey ones are much more handsome and I can't imagine it's that hard to swap out the ones in the car now.
Thanks!
Old Oct 14, 2021 | 09:47 AM
Mr_Persnickety's Avatar
Congrats on the purchase, it's a great car. If you don't mind airing these things publicly, would like to know how much you paid, how many miles, what options and where you bought it.
Thanks,
Jared
Old Oct 14, 2021 | 09:50 AM
I haven't tried removing the rear headrests or changing out the wood (check ebay for different wood trims), but I believe that the rear cover was standard (again, check ebay first).
Old Oct 15, 2021 | 07:50 AM
middleagebottlerocket's Avatar
Congrats!
I believe that it should have come with the retractable "cargo cover". I test drove three Sportbrakes before purchasing mine and they all had it "installed". The one I bought did not. I got in touch with the original owner and he explained that it had been broken and he didn't take the time to argue with the dealer about having it replaced. Who knows? I use the rear space with the seats folded down a lot so I wouldn't have it in there much since it's right in the way in that configuration. I plan on tinting the windows which should help with privacy a bit, too. If you really want one they are still available from JLR dealers but they're pricey (IMO) for what they are, e.g., https://parts.jaguarcary.com/oem-par...er-t2h37642amt
I have not bothered with rear headrest removal or trim replacement.
Old Oct 16, 2021 | 12:54 PM
I just looked at the rear headrests. I couldn't remove them but noticed the button on the side to fold them forward which does help a bit with visibility on the corners.
Old Oct 21, 2021 | 05:58 PM
pk4144's Avatar
It IS possible though I haven't done it yet. Took some digging, but found the answer on an XJ forum, if memory serves. There is a push-in tab on the outside of the door-side collar (that the steel bar slides into). That allows the headrest to slide up and down, BUT.... there is a second tab that is accessible underneath the push-in tab. You slide a screwdriver underneath it and press while pressing the button you used to tilt the rest forward on the side of the headrest itself. You do both of those simultaneously and then pull upwards kind of hard. Apparently it is best a two-person job.
Old Oct 21, 2021 | 06:01 PM
pk4144's Avatar
Congrats!
Dealership actually had two sportbrakes for sale and the salesman got me one in the other Sportbrake. Score!
SuperTrav
Aug 16, 2019 08:13 PM
SecretSupercarOwner
Jun 22, 2018 05:46 AM
Murdoch29
Jun 18, 2016 07:33 PM
bl5150
Aug 4, 2012 06:42 PM
jagxkrtoofast
Jun 30, 2010 08:53 AM
