XF (X260) 2015 onwards
Sportbrake 2014, door freezes
Old Feb 11, 2019 | 06:18 AM
Haugen's Avatar
Default Sportbrake 2014, door freezes
I have a 2013 XF Sportbrake. This winter have been rather troublesome. The front door freezes. Well, not the door, but the lock. Still after hair dryer and warm garage, it still freeze. Yesterday I had to open the door from the inside. It simply wouldn't unlock. I guess I have to grease it up. But I'm not sure how to do it. I can see three screws on the side of the door. I guess I can unscrew this, but it probably won't do anything. Do I need to remove the front panel on the inside?
Old Feb 11, 2019 | 08:54 AM
ololly's Avatar
Yes, you have to remove the door panel. Use white lithium grease as it is water repellent.
Old Feb 12, 2019 | 08:41 AM
Haugen's Avatar
Thank you!
Old Feb 19, 2019 | 07:44 PM
Suaro's Avatar
I would think that GREASE in contra-indicated. I would first ask a local locksmith what I should use, but I expect the answer is a specialized dry graphite lubricant.
1999 VANDEN PLAS
Nov 15, 2018 05:31 AM
brobragg2
F-Pace (X761) / C-X17
Oct 25, 2018 09:56 AM
Aincite
Jan 5, 2017 01:30 PM
Jaguar Forums Editor
Jaguar Press release
Mar 17, 2014 12:19 AM
sjtyrer
Jan 16, 2012 07:40 AM
