XF (X260) 2015 onwards
tail light x260 problem
Old Jun 8, 2024 | 07:20 PM
ct16jjj's Avatar
Unhappy tail light x260 problem
First time hello all.
The search engine brought me to you. I have two jaguars models, I'm a jaguar fan and I hope we can become friends.
Because about my problem, the rear light no longer works (more precisely, the one on the right - the side with the passenger). It only tries to light up when braking. The position light does not come on at all, only the turn signal works. I specify the fact that two weeks ago I installed a light (LED trunk bar - it has a plug that connects to the rear tail)...I temporarily removed it now (I thought it was from her)....I checked visually if everything is fine. Can someone explain so I can check? The fuses are good, the ones in the trunk... It seems that there is water somewhere or it is an imperfect contact but I can't figure it out. to me where the right tail plug goes under the bar? is there another link? I think it's something with the water...or what else should I check?
Old Jun 11, 2024 | 08:48 AM
UltBlkXF's Avatar
I'm not sure if the design is the same but the X250 has an LED cable in trunk that goes bad. It gives a blue screen on backup camera and tail lights go out. If you google backup blue screen there's a guy that has a good video.
Not sure if it's you issue but it could be?
Alice
16
Nov 21, 2023 11:03 AM
Binderminder
Aug 29, 2019 03:11 PM
lcmjaguar
Feb 27, 2016 11:37 PM
john501
Jun 2, 2015 10:38 AM
Bob OB
Nov 12, 2013 03:36 PM
