XF (X260) 2015 onwards
Yearly maintenance
Old Feb 6, 2017 | 08:33 PM
deville00's Avatar
Default Yearly maintenance
I have a 2015 xf portfolio 3.0 I'm due for maintenance and this one is on me.the dealer told me $468 does this actually cost that much???
Old Feb 7, 2017 | 02:00 AM
JagV8's Avatar
Mainly the cost of their shop.
Old Feb 7, 2017 | 09:41 AM
pab's Avatar
pab
What are they going to do, and what does the Owners Manual say needs to be done every year.
Jaguar - it's not an automobile, it's a Motorcar
2015 JCNA National Slalom Champion Class M
Current: '08 S-Type 4.2 "Satin Edition" (250.06 whp / 259.67 torque)
Past: '05 X-Type 3.0/auto Jaguar Racing Green
Old Feb 7, 2017 | 10:14 AM
Mikey's Avatar
No, unless it makes you feel good to throw money at your car knowing that it couldn't care less.
Why do you think the car requires an annual visit?
Old Feb 7, 2017 | 04:29 PM
Fraser Mitchell's Avatar
I would ask what is the breakdown of that cost, and what is done. You don't say what mileage you're on. It doesn't sound outrageous just a bit expensive. $468 = £374.
Old Feb 7, 2017 | 05:36 PM
Mikey's Avatar
Versus paying a local guy $75 to do an oil change which is probably the only thing that's due.
Old Feb 7, 2017 | 07:26 PM
mleskovar's Avatar
Yes if they say so. No if you go to an independent. Dealer maintenance is expensive. Search for independent Jaguar repair in Philadelphia. Cost will be determined by what they need to do for the mileage you have.
Old Feb 8, 2017 | 05:42 AM
I think it is better to wait until devill0 tells is what the work items are. For instance, there may be an air-con service in there, or brake pads.
Old Feb 8, 2017 | 08:43 AM
pab's Avatar
pab
Look in the owners manual it will clearly explain what needs to be done and when. There's no need to do anything else (other than change the oil more frequently than is recommended, and to change the transmission fluid/filter at about 60K).
My karma just ran over your dogma
Current Hers: '13 Lexus ES350
Current Mine: '08 Jaguar S-Type 4.2 "Satin Edition" (250.06 whp / 259.67 torque)
Old Feb 8, 2017 | 08:47 AM
Mikey's Avatar
Huh?
You're not going to drag that one out again are you?
Old Feb 8, 2017 | 01:26 PM
pab's Avatar
pab
Sure, what comes around goes around, right?
Old Feb 8, 2017 | 02:28 PM
Mikey's Avatar
Huh?
Old Feb 8, 2017 | 02:56 PM
deville00's Avatar
it's got just over 15k I know it's oil change but I don't know what else is involved just sounds rather high
Old Feb 8, 2017 | 03:31 PM
BCJAG's Avatar
Dealer here told me the next routine service ie oil/filter & full checkup would be about 250$ Canadian. That is fine with me. That would be at about 20K miles(mine are in kms).
Old Feb 8, 2017 | 08:44 PM
deville00's Avatar
ok thank you
Old Feb 10, 2017 | 10:26 PM
mleskovar's Avatar
Overcharge. $200US is a consistent dealer charge for oil change. Independents do it for $120US. And less. At 15K oil is the only fluid needing change. Depending on time maybe cabin filter, brake fluid, windshield wiper blades.
