2.0t Crankshaft position sensor
Old Aug 4, 2020 | 07:28 PM
3kgtjunkie's Avatar
Default 2.0t Crankshaft position sensor
Getting the crankshaft position sensor code. It's constant and won't go away even after clearing. I have the part, but I can't find any diagrams online for the 2.0t motor. Any help on locating this sensor?
Old Aug 4, 2020 | 10:06 PM
davetibbs's Avatar
I haven't seen the 2.0t engine but the crankshaft sensor for pretty much every modern engine reads a sensor wheel which is mounted to the flywheel, so you need to be looking for something mounted around the join between the engine and the transmission. Probably underneath or at least low down on the block. Usually only held in with one bolt, should be easy to identify as it'll match your replacement part.
adam699
Feb 23, 2016 02:55 PM
BKSinAZ
Nov 2, 2015 10:15 AM
randyb
Aug 19, 2014 02:29 PM
relaxed00
Mar 10, 2012 04:53 PM
Idrivejags
Dec 1, 2008 07:26 PM
