2008 XF 2.7 KOEO Values
Old Dec 8, 2017 | 04:53 AM
jimjpoole's Avatar
Default 2008 XF 2.7 KOEO Values
I'm having some problems with DPF regeneration and working my way though the TSB JTB00146v4.
Unfortunately a couple of the parameters it asks you to check look odd on my car.
Specifically: Fuel Rail Temperature and Pre DPF Temperature
Fuel Rail Temperature reads 72 degC with the car cold and KOEO and Pre DPF Temperature reads 100 degC
Disconnecting the Fuel Rail Temperature sensor, defaults it to 52 degC
Disconnecting the Pre DPF Temperature defaults it to 100 degC (No change)
Does anyone know what the KOEO values should be for these two sensors?
Pete04xtype
May 20, 2010 04:09 AM
jn_lego
May 17, 2010 11:35 AM
AJ16er
Aug 3, 2009 09:23 PM
topherscott
Nov 26, 2008 02:23 AM
